Hey guys, I've lurked here for a while but finally got around to making an account.
I picked up a second hand set of staggered Work Meister S1s in 3 piece form, 18x8 +56, 18x9.5 +62 (S2000 specs). They actually have a pretty fresh powdercoat on them that's in good shape, but I'm not a fan of the all white look or the black bolts.
This is the first set of 3 piece wheels I've owned, so I thought this would be a good DIY to take them apart and put together.
Plan is to polish the lips, leave the faces white, and replace the black bolts with gold ones. Hopefully given they were recently powdercoated, it won't take too much work to get the lips looking shiny.
Just after I picked, all with a few other new parts
Tires off the fronts, beginning to disassemble wheel #1. Tires were shot on the front, but rears have new rubber.
D'oh! Previous owner rear mounted the faces. You can imagine my horror when I start to undo the last bolt and the face dropped hanging on by a thread.
So this brings me to my question to those of you that have done this before. As I mentioned, the previous owner rear mounted the faces. Normally, Work Meisters are sandwich mounted and this is how I'd like to put them together. However, because they were rear mounted, there are now marks on the back of the faces from the nuts being tightened on them. Will this prevent them from sealing properly if I sandwich mount them? Or should I just thank my lucky spades I don't have to split the barrels and rear mount them again? See pictures for reference.
