Its not working because the inside lips are too thin(You can see it at the picture i posted, Both sides are same)
Stretching 225 on 10.5J - Need help
People saying they've done it need to shut up unless they did it with the same wheel and tire combo as the op. Different wheels are shaped differently inside and are harder to mount. Saying you did it is like saying you fit an 8.5 et 10 on your car-there's just not enough info to say it's similar.
Op, don't drive around with low pressure. That's just dumb. Take the tires off the wheels and stick pieces of wood between the beads to stretch them out. Leave them like that in a warm place for a while then heat them with a heat gun right before you put them on.
