So I'm finally finishing up building my style 5's and I've run into a snag. I got two together without any problems. But on the last two, the centers won't just drop into the barrel. The first two just dropped in and pulled in when torqued. The two I have left won't even go together if I lightly tap them in with a hammer and block of wood. Id really like to get these done ASAP so any help would be much appreciated.
Style 5 Help ASAP
Tags: None
I looked and there is no paint on that edge on the center and the barrel is clean too=\ they were in snug when I removed them. It doesn't matter which barrel with which center does it? I never labelled them
I can hit them that hard without hurting anything? To remove I gripped tj
Je center tightly and pounded them flat on the ground (with a towel underneath) and then proceeded to crush my hands into the floor while keeping hold of the center. Lol
put the center in a freezer over night, and start heating the barrel with a heating gun, when the rim were the bolts go in, is hot enough, you take the center and drop it in. easy as 1 2 3.-
Instagram@jdjurhuus
Stretchsaurus and Pokemon.
I don't think I can do the heating method though because i cated them in sharkhide and it might get funny
Anyone else have any good ideas?
^lol how hard can I pound on these to put them in? I dont want to bend the barrels
I've got the block of wood, but I don't know if I have the strength. May need my dad to help. Lol
