Originally posted by JVC
View Post
best wheel/tire calculator. ever.
This topic is closed.
This is a sticky topic.
lurkin and murkin
and rim 16 ...
For a rim 16 which I can put wheel with little profile.
hi,
It is really very good site. It may help a lot for all members.It contain important informtaion about wheels and others .Thanks for shearing the wonderful site.
2013 MERCEDES BENZ SL-CLASS
Am I the only one seeing problems? I put in exact measurements from my car. It shows a 7.1mm ride height dif from stock to 18's but it's a lot more than that. Atleast a half an inch. Plus, it says that my 18's wouldn't clear oem strut assembly (which it does). I don't currently need a calculator, but it worries me.
That's the one I used when researching wheels and tires for mine.
+1Originally posted by starbai View PostNot to take away from the OP's post, but I also really like this one:
I like sizemytires as well..
I like sizemytires.com and then there are plenty of alternatives of sizemytires.Originally posted by Rollmodl View PostThis calculator is much better http://www.tire-size-calculator.info/
Use this tool to compare two tire sizes. The tool can be useful for finding out whether or not an alternative tire size is compatible with your vehicle.
Hey John thanks for that, just checked our projected tire size:
We're within range. Too bad it doesn't allow for specific car/vans. I think to get an accurate reading is to us all of those site listed. But currently I'm helping wheel-size.com with their specs.. seems someone transfered over the Gen I spec sheet over to the Gen II spec sheet.. I'm seeing allot of numbers that aren't correct. Hopefully Alex will get this taken care of shortly.The overall diameter variance of the new tire is 16 millimeters , which is 2.49% different than the original. You should never go beyond 3% of the original tire, otherwise you run the risk of brake failure.
Resources:
Wheel-size.com
TacomaWorld.com
RimsNTires.com
DiscountTire.com
Locate the Rim & Tire Manufactures Home Page:
KMCWheels.com
WheelPros.com
Maxxis.com
Avoid/Fail:
TireRack.com (Will not allow you to modify your wheel/tire specs)
CariD.com (Sold a wheel/tire package to my bud, the tires were over 2 years old)Last edited by ToasterVan; 06-16-2015, 07:49 AM.
