It can be done but it looks absolutely retarded because the stretch is too extreme.
195/45 tyre on a 17x10 rim?
^^^this. also i tried with 215/45 on my new 17x10 et17, and i can say that still doesnt rub, but when i'll lower it with 1-1,5inch all around and will try to run the 40 series...Originally posted by Dr.AK View PostIt can be done but it looks absolutely retarded because the stretch is too extreme.
you guys are talking all this 215 40 stuff which would stretch alot different the a 195 45
the side wall is taller so it would be much more pliable
45% of 195 is different then 40% of 215 not by much but enough.
from what i understand 06tiburonofdoom drives his car frequently with a 195 on a 10 and so have a few others... it all comes down to what tire you would be running OP i say go for it
HoodRatStatusInstagram @looneylow
haha, thanks but actually as you can see it's not necessary...Originally posted by FittedDownLow View Postyou guys are talking all this 215 40 stuff which would stretch alot different the a 195 45
even with those 215/45 after running 2-5miles on the shitty roads one of the tires began to make noises like "pssssssssssst" -
and it was at 3,5bar (~50psi) can you believe it? So i'm sure that if i run 215/40 i won't be able to roll them, because of the roads, fawk!
10_195/45 r13Floccinaucinihilipilification
too much i would say
this looks okay tho
sometimes wheels will leak, if you have to much pressure in them.Originally posted by projektzwo View Posthaha, thanks but actually as you can see it's not necessary...
i would personally only go high as 2.5bar.-
Instagram@jdjurhuus
Stretchsaurus and Pokemon.
this is really good info... So if i had a 165 45 15 on a 15x8 around what tire pressure would you recommend to run?Originally posted by Zic View Postsometimes wheels will leak, if you have to much pressure in them.
i would personally only go high as 2.5bar.HoodRatStatusInstagram @looneylow
