Stance Accord: Vossen CV2's Black w/Machine
  • #16
    hmm... mixed feelings here, i say try to match the front by adding a 20mm spacer and throwing alot more camber in the front, OR run a more stretched tire in the rear and dial in less camber. whatever you do try to have front and back camber match!
    Instagram: _jay_borcena_
    • #17
      way too much camber in the rear for those rims, adding spacers will def work...
      also those vossen's are not my cup of tea...
      flickr
      • #18
        Thanks man, I already adjusted the camber.. and added 15mm spacer at the front, just need to cut my fender so i can readjust camber and add spacers.
        .. It's adjusted..
        I need to add pictures just here at work i have a Blocked IP.
        10' V6 Coupe BBP
        • #19
          Here are some updated front pictures.
          So i added a 15mm spacer so now the offset is 32+15 "spacer"= +17offset
          Here are some updated rear pictures.
          Brought camber about 2 degrees less and i raised the rear about 1/2 inch. It's still a +25 offset i can't add any spacers right now until i get my fenders cut, after that i will put more camber maybe like -3 or so, not like before much less but still camber.. and then after adjusting the camber i will slap on a 10mm spacer to get back the poke.
          10' V6 Coupe BBP
          • #20
            love it man! i think those wheels are HOT!
            • #21
              Spacers definitely make it better, but I'd like to see a little less camber out back. Love the concave on the wheels though.
              - Kielan (Key-lin)
              • #22
                Thanks man..
                The camber in the rear has been adjusted completely, it's almost at Factory SPEC.
                The rear picture is with camber almost to Factory instead of the -4 camber i had in the rear before
                10' V6 Coupe BBP
                • #23
                  ur car is raw i seen it on the thursday meet at london square , good sht
