Hey everyone, I just picked up a set of Work VS-SD's for my s14. Before I put them on, I would like to either refinish or powdercoat them. I have never taken apart a 3 piece wheel before so I am wondering if it is something I should attempt myself or should I just take the wheels somewhere to be on the safe side?
Need help disassembling wheels
Find out what type of bolts they use. Common ones are M8 12pt, so just get a 8mm 12pt socket for the bolt heads and a common 10mm 12pt for the nuts and have fun.Originally posted by Nismofo View PostHey everyone, I just picked up a set of Work VS-SD's for my s14. Before I put them on, I would like to either refinish or powdercoat them. I have never taken apart a 3 piece wheel before so I am wondering if it is something I should attempt myself or should I just take the wheels somewhere to be on the safe side?Originally posted by Jesus Christif "life, liberty and the pursuit of happiness" doesnt include being able to buy a huge veiny motherfucker then the declaration of independence isnt worth the hemp it was written on.Originally posted by Jedidiahhe speaks the truth.. he doesn't even have the -- -- eyes.
I did not have a 8mm 12 point so I used a 12 point closed end wrench, and then I exerted force on the 10mm 12 point. I found it also helpful if you break the bolts loose first from the back only, then when you go to remove them you can use an electric impact drill to make the job go quicker. If you are going to be reusing your bolts I suggest putting plastic wrap over bolt then the wrench/socket to act as a protective layer between the two.
this is the impact driver i used.
an example of the 12 point 8mm box end that i used as well.. (didn't have a socket and I did not want to buy one)
Don't powdercoat where the bolts are going if the wheels are sandwich mounted (just powder the face that you see). If they're reverse face or face mounted, it should be fine as long as the powdercoat isn't REALLY thick.Originally posted by Nismofo View PostOk thanks for the advice. Now what about re-assembly? Any kind of special adhesive? And if I get them powdercoated will the extra thickness of the powder and clear coat affect how the wheels are re-assembled?
I just use Permtex RTV silicone which you can find at Wal-Mart or Autozone.
Good DIY Thread:
Do they make that in a big enough tube that you could use a caulk gun?Originally posted by extol1337 View PostDon't powdercoat where the bolts are going if the wheels are sandwich mounted (just powder the face that you see). If they're reverse face or face mounted, it should be fine as long as the powdercoat isn't REALLY thick.
Good DIY Thread:
http://www.the-polisher.com/id6.htmlE12/E39M/E53
