Originally posted by ShadowWabbit
View Post
GTI fitment question
I have a question. Why have you settled on the 2.5in drop? Whats the reasoning behind that exact number? There is no formula that you can plug variables into, it varies depending on what your looking for.
Maybe a better way to go about this is to find a pic of a mk4 you like, and then we can help a little more by telling you what it took to achieve that.
Edit: i just realized you were talking about the sig pic. That car is on air, with pulled fenders, camber shims and 18x11in wide rears with something like a 225/35 or 225/40 on the wheel.
so in short:
No.Originally posted by vRbeHavior View PostSo, if I wanted to do a 2.5 inch drop and stretched tires like the second image would I be able to pull that off with 17x9s all around?Last edited by Tuck&Poke; 09-08-2010, 08:56 PM.
ig: @jonnie86
i wasnt trying to be a dick but there is no second pic... i think ur looking at Ignapu's signature lol which is of a nicely pulled fender and cambered wheelLast edited by ShadowWabbit; 09-08-2010, 08:55 PM.
alright, then I guess something was lost in translation. I was thinking 10 deep because I don't mind if they poke as long as the tires's are stretched but, again, I dunno if thats too wide. Looking at that signature of the pulled fender and the cambered wheel my first reaction would be that the wheel is at least 9 deep????Originally posted by ShadowWabbit View Posti wasnt trying to be a dick but there is no second pic... i think ur looking at Ignapu's signature lol which is of a nicely pulled fender and cambered wheel
i answered this aboveOriginally posted by vRbeHavior View Postalright, then I guess something was lost in translation. I was thinking 10 deep because I don't mind if they poke as long as the tires's are stretched but, again, I dunno if thats too wide. Looking at that signature of the pulled fender and the cambered wheel my first reaction would be that the wheel is at least 9 deep????
ig: @jonnie86
To be honest I came up with 2 1/2 based on a few cars I saw. Most of em have a pretty decent drop @ 2.5inches. I noticed one civic that was on the ground at a 3 inch drop but it was still manageable to drive so thats where I came up with that number. Personally 2.5 inches isn't a must. I'm just honestly looking for a drop that makes the wheels look flush and slightly tucked. If the fenders need to be rolled, I'm down for that too. Also I figured 15 inches would allow for a good drop without the risk of rubbing. I don't have enough experience with my VWs. All my VWs have been factory ride height. I had an LS Integra on the ground but I bought it like that. So this is the first VW thats actually a good platform without having to rebuild the WHOLE car.Originally posted by Tuck&Poke View PostI have a question. Why have you settled on the 2.5in drop? Whats the reasoning behind that exact number? There is no formula that you can plug variables into, it varies depending on what your looking for.
so in short:
No.
What I'm looking for is something like this:
I'd even be willing to go lower but from the looks of the picture, going lower would probably require bags without rubbing. According to the title, this is a static drop.
getting a mk4 low is another animal from gettting something like a dc2 low.
First, oilpan is one of the lowest points, and its also made of aluminum, so they dont bend they shatter. That silver car you posted probably has about an inch from the lower control arm mount to the floor. That's more in the range of a 4+in drop. At that kind of drop you're also going to run into problems with the axle hitting the frame, so its going to need to be notched. Also going to need to either remove the sway bar or buy a hotchkis sway bar that doesn't go over the axle. Your also going to need a set of coils that will get you that low, like first gen weitecs or B&G's. I haven't owned a mk4 in a while so I haven't kept up with some of the newer stuff as much, there may be other brands that will go that low. I'm not sure they even still make B&G's. Raising the motor helps with oilpan clearance issues and will also help with axle binding, and depending on what motor you have, you can either run a mk3 steel pan or a hybrid pan if you have a 1.8t. I dont know the specs on those wheels but i do know they're 17's. Im sure someone else like aaron or calvin can chime in on more details
ig: @jonnie86
Hmmmm, if thats a 4+ drop thats a bit low for me. I want to go 3inches max on the drop. Would I still have those issues with a 3 inch drop??Originally posted by Tuck&Poke View Postgetting a mk4 low is another animal from gettting something like a dc2 low.
That Silverstone GTI above is at around 22" from ground to front fender, it's absolutely slammed on coilovers and most people wouldn't be able to drive it without breaking things. On a MK4, you can run into any of those problems listed above with even a moderate drop, it depends on the car and on a VR, the pan is stupidly low. I recommend doing some more research before you decide on anything. Check out the various picture threads and stuff on VWVortex, lots of good examples on there.
Is it just me or is this guy getting waaay ahead of himself? Research and buy a set of coils that have enough "low" and since ur still in the learning stages I recommend buying wheels that came off a nicely stanced mk4 and use em as a start. Then dial out the problems and dial in the stance some more.
U won't really learn till u just jump in! I was wer u r right now ~4 years ago and I learned the most from reasearching, trying shit and fucking shit up
I was looking at a few pics last night. I figure I'll just get the drop job done by end of the year with a set of coilovers ( probably FK streets?) on my factory tires to see how everything feels. Then I'll test fit something with a larger diameter. I think my factory wheels are 16s. I have a VR and I'm already scared I'll crack the pan open so I'm looking to get a skidplate :-\Originally posted by aar0n. View PostThat Silverstone GTI above is at around 22" from ground to front fender, it's absolutely slammed on coilovers and most people wouldn't be able to drive it without breaking things. On a MK4, you can run into any of those problems listed above with even a moderate drop, it depends on the car and on a VR, the pan is stupidly low. I recommend doing some more research before you decide on anything. Check out the various picture threads and stuff on VWVortex, lots of good examples on there.
I know everyone has to start somewhere, but I suggest you do FAR MORE research before you do anything.Originally posted by vRbeHavior View PostI was looking at a few pics last night. I figure I'll just get the drop job done by end of the year with a set of coilovers ( probably FK streets?) on my factory tires to see how everything feels. Then I'll test fit something with a larger diameter. I think my factory wheels are 16s. I have a VR and I'm already scared I'll crack the pan open so I'm looking to get a skidplate :-\
That GTI you posted is around 21 7/8" ground to fender in that picture which is about a 4.25" drop. My car (MK4 Jetta in my sig) is @ ~22 flat (around 22 1/8") which is a little under a 4.25" drop as well.
The OZ's you posted is 17x8.5 ET17 with 205/45/17 and 17x10 ET30 215/45/17. See how it fills up the wells? I also suggest you research how tire sizing works.Originally posted by Jesus Christif "life, liberty and the pursuit of happiness" doesnt include being able to buy a huge veiny motherfucker then the declaration of independence isnt worth the hemp it was written on.Originally posted by Jedidiahhe speaks the truth.. he doesn't even have the -- -- eyes.
Originally posted by extol1337 View PostI know everyone has to start somewhere, but I suggest you do FAR MORE research before you do anything.
What problems do you run into with that kind of drop when you're driving around town? Also, can you drive it aggressively?? I'm thinking I won't even come close to 3inchs low based on what you guys said and the issue of clearance on the oil pan. From the research I've done on VWvortex, everyone seems to like the FK Streetlines for a beginning set of coilovers. Running that on my factory shoes will give me an idea as far as what I can do with clearance.
On VRs, you definitely need to watch out for the oil pan. EuroImage sells motor mount spacers if you want to raise the engine up. I love mine.Originally posted by vRbeHavior View PostWhat problems do you run into with that kind of drop when you're driving around town? Also, can you drive it aggressively?? I'm thinking I won't even come close to 3inchs low based on what you guys said and the issue of clearance on the oil pan. From the research I've done on VWvortex, everyone seems to like the FK Streetlines for a beginning set of coilovers. Running that on my factory shoes will give me an idea as far as what I can do with clearance.
Skid plates help as well, but still will kill your pan if you hit something hard enough to bend the plate onto the pan.
I drive quick sometimes on the highway, that's about it. As far as city driving (driving in general), I scan the road constantly so I don't encounter something that'll kill my engine.Last edited by Han; 09-09-2010, 06:43 PM.Originally posted by Jesus Christif "life, liberty and the pursuit of happiness" doesnt include being able to buy a huge veiny motherfucker then the declaration of independence isnt worth the hemp it was written on.Originally posted by Jedidiahhe speaks the truth.. he doesn't even have the -- -- eyes.
sounds like those spacers are the way to go before I even consider dropping the car hard.Originally posted by extol1337 View PostOn VRs, you definitely need to watch out for the oil pan. EuroImage sells motor mount spacers if you want to raise the engine up. I love mine.
