Hi,
So I fitted a set of MK Motorsport alloys to me E60
20x9 et15 225/35
20x10.5 et22 255/30
I've put 12mm spacers on the front, maxxed the standard camber and got it pretty much where I want it with scrubbing only on really harsh bumps.
The rears I put a 15mm spacer and they sat perfect! On compression however the tyre clears but its the rim protector that catches. I removed the spacers and it all clears but there's still not a whole bunch of room! There is maybe a touch more camber to be had but not much more, but even if there was, to dial in that much camber to clear will mean the top of the wheel with have to tip in anyway!
How do you boys do it? Is it just a consequence of having small profiles???
I tried fitting these same wheels on my M3 and they looked great but again to get that nice look where the rim just pokes it would hit the arch on the rim protector. I'm waiting on new wheels for the M3 that are more aggressive but 18s, just hope they'll fit!
Both the lips have been rolled on both cars at the back. They're not flushed just rolled back still leaving 10mm of lip maybe???
Any advice appreciated.
20x9 et15 225/35
20x10.5 et22 255/30
