as much as I wanted to avoid this item, but polishing to be.
There are several reasons.
firstly new to me lacquer Solid... and as you know, every
varnish has its fluidity and other properties are different from others.
and secondly, the number of layers of varnish applied in one go
layer cast, after some time, the second and the last pulls slightly previous.
with Bruixa I was not like this... but here goes solid more fluid.
enough of the lyrics...
sandpaper 1500... knock shagreen rigid heel 20cm
next, the same heel harvested at risk 2000 grain
then 2500 paper RUB clean hand the entire surface to facilitate polishing circle.
the white circle (from the color depends on the stiffness) pasta 1 by 3M
and went...
and went...
