99 SVT Contour track slut by PRT Autosport.
  • 99 SVT Contour track slut by PRT Autosport.
    Hey guys! I've been following the forums on SW for some time now, and finally got around to finding time to share my build for the 2011 season.
    A short about me: Name is Josh, and I run a performance fab shop, PRT, that's still in it's infancy but quickly on it's way to becoming the full-time job I've always dreamed of. I got my start a few years ago when I bought my first car and am completely self taught mechanically. I've made a strong name for myself over the last few years in the CSVT game and started branching out in 2011, so far things are going rather well and we're pumped to see what 2012 has in store.
    I built a track car earlier this year as a tool to promote the shop, my name and my car. Sadly my build thread was lost thank to a forum crash on another site, but I recently had a shoot for a feature on stancewi.com so I figured i would share it with you guys. Hope you enjoy!
    Link to build thread:
    Follow along with our fun:
    PRT, Pewaukee, Wisconsin. 1 like. Street driven. Track proven!
    On with the feature:
    “PRT BILT” – PRT’s 99 SVT Contour, the street-driven track whore.
    “Why a Contour?” - The one question I get more often than any other. Quite simply, I bought one as my first car and fell in love. There was only one problem….I wanted to make the car my own but lacked a supporting aftermarket. What I did have, was a passion for design and fabrication.
    Enter PRT, the company name I began associating with the parts I built for myself and others. It all started small with simple things like urethane engine mounts and fiberglass gauge pods. Over the next six yearsI proceeded to churn out small numbers of parts and occasional full car builds and the shop was growingsteadily, but there was still one big problem looming over head. Wisconsin winters and a shop with no heat meant my hobby, my passion, had to take a break five months a year. That was until the winter of 2010.
    It was then that I happened upon a heated work space for the last few months of the winter. With no customer cars waiting for my attention,it was time to build something for myself. The car, the first SVT I had ever owned, was pulled from the corner of the shop and moved a week later and I got to work. I came into the project with a notebook full of ideas. I had pages upon pages of parts and modifications I never had the time to bring to life. The goal here was simple, build a fun and capable car for me to enjoy that also showcased my abilities in hopes of expanding my services outside of my current niche market.
    The car’s chassis was heavily modified to reduce weight while stiffening its structure and reducing the interior to a literal shell of its former self. The engine was swapped for a larger displacement 3.0L unit and while it may be naturally aspirated, it’s no slouch in the straight line. Braking late and cornering fast was next so aggressive rubber and the largest brakes that would clear the wheels were fitted using some my own custom brackets. The car also received a track ready re-paint in the form of John Deere chassis enamel and a few aesthetic modifications were thrown in during the process. Just four months of late nights and long hours later I debuted the car at Nelson Ledges in Ohio at the national Contour meet’s track day. It was everything I could have hoped for and performed beyond expectation.
    It wasn’t long after my return that I found StanceWI.com and things only continued to get better. The car has since seen numerous shows, several thousand miles, a few different drivers (ahem Preston)while opening the door to a great group of people. I’ve got more plans for the car this winter and I’m also hard at work on another build that I look forward to sharing next season. For those of you I have met, it’s been a pleasure. As for the rest of you, I look forward to chatting, cruising, and all-around “staying awesome” with you next year!
    Key Changes-
    Drivetrain Performance:
    PRT port-matched Ford Escape 3.0L engine swap
    SVT-spec camshafts
    Upgraded and aluminum pulleys
    PRT power steering delete
    Mustang 65mm throttle body
    Extrude Honed “max-honed” upper intake manifold
    Ported lower intake manifold
    MDSD headers
    PRT high-flow Y pipe and mandrel bent exhaust
    Spec stage 3 clutch and flywheel
    Quaife LSD
    Emissions systems deleted
    Chassis Performance:
    520 lbs. overall weight reduction
    Tubular harness bar/x-brace/rear strut tower bar
    PRT full tubular rear suspension
    Up-sized front and rear swaybars
    PRT sway bar end links
    Koni adjustable struts
    Ground Control coilovers
    PRT 13” Mustang Cobra front brake conversion
    PRT 11.8” rear brake conversion
    Rev. Model 12 17’s
    Toyo R888 tires (235/40/17)
    Interior:
    CorbeauForzaII seats on custom brackets
    Corbeau 4-point harnesses
    Stripped dash and interior re-wire
    PRT dual 2 5/8” gauge pod
    Lo-tek pillar gauge pod
    Aesthetics:
    Shaved emblems, body seams, antenna and
    John Deere Blitz Black full re-spray
    PRT badgless front grill
    Color matched chrome trim
    Tinted tail lights
    Yellow tinted head and fog light lenses
    Samco Ford Mondeo hose kit
    Metallic silver engine powder coating
    Owner/Operator PRT Autosport : www.PRTAutosport.com www.facebook.com/prtautosport
    99 SVT "BLKOUT2" - PRT street driven track whore / 00 ROUSH Cougar / 98 SVT - PRT RWD conversion project car
    nice
    My first JDM project after decades of European cars!
      Pretty nifty.
      MB Obsidian Black Metallic Crossfire SRT-6
      Instagram - @osshwa
        badass local car!
        Straight Outta Wiscompton
        Team Gileto. Graphics-Coatings-Performance
        Shakotan Midnight - Low Car Street Team
          Haha that's so cool man. How much power is it puttin down?
            That thing is pretty baller, and I would say it makes around 220-240whp.
            Fuck Rotas, I'd rather my wheels not break apart when I drive over a watermelon seed.
              Since the 3L install, I'm sitting at roughly 220WHP un-tuned. While that doesn't sound like much, the car's weight and gearing make it a beast on the track and a lot of fun on the street. Tuned I should net around 240. Again, not a ton of power, but all of it useable on the track.
                I bet it sounds pretty wicked at full blast too... Props man!
                The daily: 2009 Honda Fit Sport
                Buddy Club N+ Coil Overs
                Rota D2 17x8.5 et48f et40r after 8mm spacer
                Honda Accord dual exhaust tips
                Blacked out headlights, tinted tails and fogs, painted rear bumper section.
                Click here to go to my build thread
                Check out my blog for automotive awesome you cannot hope to comprehend:
                Safety Stance
                  Pretty cool man. It looks like a late 90's Touring car.
                    normally i really dont like the murdered out look, but this car makes me reconsider!
                    love it!
                      Best I can do right now, this was an early shake down run back when the car was still 2.5. I have nothing in/out of car since the 3.0 swap, but the change in tone since is ridiculous.
                      A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
                        that's a really strong phone HAHA. but seriously, I never thought I'd say it but that contour is badass!
                        $W∆G
                          Hey Josh!
                          Your blast pipes look stupid.
                            lol damn
                              i dig it
