Project Fix-Stance
Guess I must be lying about my camber..better yet, I am lying and u caught me. WTF??? (sarcasm intended).Originally posted by patrick_irwin View Postthere is no way you are running -4 in the rear. and you ill never get that clean look with the low of a rear offset. most ppl with mkv's run anywhere from 45-28. 15 is just way too low.
and you need to bring that rear down
Btw, ever consider that I may not be going for "that clean look".Last edited by mrx928; 10-17-2010, 06:25 PM.
Thanks for the heads up. Sounds like i'll need some actual body work to pull the rears correctly.Originally posted by Rabbit View PostBe careful when you pull those fenders man. The MK5 fender creases in the middle because of the material on the inside. These fenders are a pain to pull even though they are paper thin.
