Euro ToYoTa CoolRolla :D
6-7 months ago I said that I had no patience waiting to do the bend and I've installed it as it was.
But, after few days I had to pull it out because it was very difficult to change gears, it was a bit further then needed.
Then I did this "project" and thought how will I modify that shifter to suit me better
...and for several months I didn't use shortshifter at all, and I didn't try modifying it at all...till today!
A friend of mine took this job seriously. First he just bend it a bit, not as in my "project" but similar and a lot easier
...so I tried it but still it wasn't enough, my elbow was slipping from the arm rest. So, than he lengthen the upper part for about 5cm (that is still around 3-4cm shorter then oem, and the lower part is around 10-12mm longer then the oem one)...
For now it will stay this way. I will drive it for a few days and if it's good, I won't change it any more
First spring cleaning
New tyres at the rear, GoodYear Eagle F1 Asymmetric 215/35/18, dot4413
And I've played a little with cans of Heineken-a
It will be 200.000km soon
Front bumper took 2 new hits at the parking and this Monster sticker is already washed, so I will put other bumper that is already painted, and there will be oem spoiler at the bottom...
It's been years that my brakes are bad, so finally I had a chance to see the problem...
And I was wondering why my car's brakes are bad!? :/ Textar new discs and pads at the back straight away!
It's a lot better now, braking fine, even the handbrake works now, practically I didn't have it at all till now. :/
Maybe I will upgrade front brakes soon with some bigger calipers and discs
Decided to take down the foil, it bored me already and started to peal on some spots...
Monster sticker bored me after few seasons and I've changed the bumper, and also put slightly modified oem spoiler lip from the facelift model, there were small holes in it so I've put some aluminum mesh in it...
Active subwoofer Kenwood ksc-wa100 that works pretty good
