Project Crowdmower : Ford Chassis, Chevy Motor, and Nissan Transmission
  • Love the space, looks like an enjoyable place to wrench honestly. Here in AZ, I'd almost prefer a semi-enclosed space like you have, so heat has a chance to vent. I knew a guy who had a full enclosed RV garage, and in the summer it became a complete oven. Borderline unusable when it's 120 out and there is zero airflow inside his concrete box.
    Looking forward to seeing progress on the Mustang now that you have it back!
    • Originally posted by bwwaaaa View Post
      Its MUCH more space than I had at my old house. Once the house is in order, yard taken care of, and wife and I have new daily drivers (she needs a bigger one and im STILL fighting Subaru on my brz) money will get allocated to close in the garage, lift the roof height on the left side and insulate and AC it. Hoping to start that in about a years time. Obviously the sooner the better.
      IG @gt3_brz
      My Mustang Build
      http://www.stanceworks.com/forums/sh...=1#post1552949
      My BRZ Build
      http://www.stanceworks.com/forums/sh...ad.php?t=86482
      My F100 Build
      http://www.stanceworks.com/forums/sh...ad.php?t=97329
      • Started some work on the mustang this weekend in-between yard work (That kicked my ass).
        Started by making a short to do list of items I wanted to work on. Don't have a ton of spare funds to put towards ole girl right now so trying to make do with what I've currently got parts wise and get maximum work done. Put the front end up in the air, pulled all the suspension out and started some of the metal work. Didn't get too much done but its a start, and its forward progress. I was also able to get the TIG from over at my dads. Ive got his truck for the week as he is on a business trip. I will be utilizing it to also get my motor and trans to the garage as well.
        IMG_2684 by lawrx, on Flickr
        IMG_2680 by lawrx, on Flickr
        IMG_2681 by lawrx, on Flickr
        IMG_2682 by lawrx, on Flickr
        IMG_2683 by lawrx, on Flickr
        IMG_2678 by lawrx, on Flickr
        IMG_2844 by lawrx, on Flickr
        IMG_2842 by lawrx, on Flickr
        IMG_2841 by lawrx, on Flickr
        IG @gt3_brz
        My Mustang Build
        My BRZ Build
        My F100 Build
        • Found some more time to get some work done between hours work and side jobs I have been doing.
          Ordered in a condenser and two small cooling fans to keep it cool. Ive decided to run large single a2w intercooler between the turbos and move the rad and heat exchanger to the rear. I bought some card stock and did a full size mock up to verify it would fit. While it is tight it will fit, should work perfectly. Reduces complexity of tubing substantially, as well as length by over 6ft. Which will be huge between the turbo size and small motor I plan to run, will definitely help with spool and throttle response time. Core is a CSF 2000 hp 12x12x6. Way overkill but I want everything to be overbuilt on this car. Minimize stress from heat as much as possible to keep it reliable. Condenser is a 24x12 and fans are Spals 6.5'' units. Should be plenty of airflow for the condenser. With now having just the condenser up front ill be using the active shutter I got from a Honda CRV I think it was, which will at a set speed close on demand, blocking flow through the bottom of the bumper to reduce drag for high speed runs. I may look into doing something similar for between the turbos so that the only opening is to the turbo inducers for maximum efficiency at high speeds.
          I have everything on order material wise to construct the intercooler except for the connections, which I will be using LPS Alphaloc's. Buddy of mine is a fab guy and recommends them, and he will also be the one constructing the end tanks and such on the intercooler once the material arrives. Ive also got the material on order, which arrives tomorrow, to build the ducting and mounting for the condenser and fans.
          IMG_3344 by lawrx, on Flickr
          IMG_3345 by lawrx, on Flickr
          IMG_3355 by lawrx, on Flickr
          IMG_3357 by lawrx, on Flickr
          IMG_3365 by lawrx, on Flickr
          IMG_3362 by lawrx, on Flickr
          IMG_3360 by lawrx, on Flickr
          IMG_3351 by lawrx, on Flickr
          IMG_3349 by lawrx, on Flickr
          IMG_3361 by lawrx, on Flickr
          IMG_3364 by lawrx, on Flickr
          IG @gt3_brz
          My Mustang Build
          My BRZ Build
          My F100 Build
          • A nice workspace is a beautiful thing. Glad you've gotten some time in on the mustang again. The two turbos peeking out of the grill is sick.
            • Material showed up for the fan shroud. Is my first time cutting and working with carbon in this manner. Cutting it SUCKS. Its hazardous to breathe in, makes crazy fluffy dust piles and sucks when you get it in your finger. In these pics its all just mocked up, I later glued it all a little neater. Still need to cut holes for the fans, make some brackets to mount it to the condenser, and then make brackets to mount the assembly to the chassis. I will be cutting off the lower tie bar of the 417 turbo front end and going with a smaller, lighter setup being I'm just hanging the condenser only off of it. Eliminating weight waste.
              IMG_3440 by lawrx, on Flickr
              IMG_3438 by lawrx, on Flickr
              IMG_3442 by lawrx, on Flickr
              IMG_3439 by lawrx, on Flickr
              IMG_3448 by lawrx, on Flickr
              IMG_3443 by lawrx, on Flickr
              IMG_3445 by lawrx, on Flickr
              IMG_3447 by lawrx, on Flickr
              Also took delivery of parts needed to build my intercooler. Throttle body, BOV's, Alloy flanges, water ports, and intercooler core. Which I accidentally ordered the wrong core, new one should be here today. Ill hold on to the incorrect one as it actually fits the bill perfectly for next car ill be building. Ive also got a cobra rear bumper on order through my local ford dealer. I can get it at cost which is cheaper than a used one and no damage to fix. Sadly it is currently on back order so there is a wait on it. Good news is I don't need it right away, need to get some funds to order heat exchanger and radiator before the bumper is a necessity. All that's left for the intercooler fab is the LPS Alphalocs ill be using. Have to order them again when I get some funds as they are pricey, but man are the awesome. My buddy Jami will be doing the fab work on the intercooler, works at Scott's Hotrods. Check him out on IG @chaz_mcnasty.
              IMG_3451 by lawrx, on Flickr
              IMG_3452 by lawrx, on Flickr
              IMG_3454 by lawrx, on Flickr
              IMG_3453 by lawrx, on Flickr
              IMG_3455 by lawrx, on Flickr
              IMG_3457 by lawrx, on Flickr
              IMG_3458 by lawrx, on Flickr
              IG @gt3_brz
              My Mustang Build
              My BRZ Build
              My F100 Build
              • That is a thick core if I've ever seen one!
                FB: @DumbassCarCrew - IG: @fruttolo_dumbasscrew
                • Originally posted by Fruttolo View Post
                  yep 6'' thick. correct core is 12x12x6. this one is only 12x6x6. Correct core is good for 2000hp of cooling capacity. PLenty of head room and wont tax the system when i turn it up. Reliability is a strong focus with heat management playing a major role in that.
                  IG @gt3_brz
                  My Mustang Build
                  My BRZ Build
                  My F100 Build
                  • Hey guys bit of an update, been kind of MIA lately. Hadn't really touched the cars at all in the last several months. My daughter has been keeping us running around and working on the new house has taken the rest of my time and money. Been having to walk next to my cars and just look a them, not even working on them or buying any parts. Sucks but its where I'm at right now. Luckily its for the better, we are making progress on the new house. Built a front fence, sodded the front yard, pulled out a ton of overgrowth etc. And the REALLY good news is we are in the planning stages of my bidding my dream garage. We are hoping to break ground on it by spring of 2020. Will have room to comfortably work on 4 cars, and space to park 6, possibly 7 depending on car lengths. 2 post lift, race deck flooring, heat and a/c, an 8ft deep loft in the back for hanging out in. Im super excited. Going to be about 48x27, with an extension after the fact to add in another few hundred square feet. In total it should be around 1600-1700 sq ft. Which coincidently is the same size as my house. Have space allocated for a separated clean engine assembly area, space to build an autoclave to venture into making my own carbon parts and storage to park my eventual multiple cars. The drawing below is still preliminary as im still trying to decide on a few things in regards to placement.
                    IMG_3189 by lawrx, on Flickr
                    IG @gt3_brz
                    My Mustang Build
                    My BRZ Build
                    My F100 Build
                    • Congrats on the new garage plans. I love the new garage I have, but wouldnt mind a little more room like you are planning. Totally understand having no time, I just moved and still have a lot to grab, and also get my other house ready to sell while working on the new place. Adulting is fun haha.
                      Insta Mintyhinrichs
                      • Whats up everyone, been a whiiiiiiile. Work, kids, new house, leaves no time for projects. Sadly this isn't directly a update on the mustang, rather on the garage. Original plans were to tear down the existing structure and build new. Sadly after talking with a construction friend about setbacks, yard intrusion with size, cost etc. Its just not feasible. So plan B is to close in and use the existing structure.
                        The current structure is 48x21. One half the width at 11.5ft wide has a 13ft sloping to 12ft roof. the other 9.5ft width has a 7.5ft sloping to 6.5ft roof. And down the middle is a 4x4 post every roughly 7 feet. I have some plans to remedy some of these post but I will get on to that at a later date.
                        My first step was starting to close in the open sides, as the back, half the left side, and none of the right or front have walls.i started out by putting up some 2x4's and starting the frame work of barn style doors for the short side of the garage.
                        IMG_6386 by lawrx, on Flickr
                        IMG_6573 by lawrx, on Flickr
                        IMG_6574 by lawrx, on Flickr
                        IMG_6385 by lawrx, on Flickr
                        Given I was restricted to using the existing structure and its painful weird layout, I decided to build a few cutouts to maximize space. the first is on the side, 2.5x 2. it is slightly raised, as frankly I did not want to dig 6'' of mud out to make it flush. This area will be used for heavy stationary tools. Lathe, mill, hydraulic press, drill press etc.
                        IMG_6438 by lawrx, on Flickr
                        IMG_6440 by lawrx, on Flickr
                        IMG_6489 by lawrx, on Flickr
                        IMG_6494 by lawrx, on Flickr
                        IMG_6662 by lawrx, on Flickr
                        IMG_6664 by lawrx, on Flickr
                        IMG_6665 by lawrx, on Flickr
                        IMG_6833 by lawrx, on Flickr
                        IMG_6832 by lawrx, on Flickr
                        IMG_6689 by lawrx, on Flickr
                        IMG_6766 by lawrx, on Flickr
                        IMG_6850 by lawrx, on Flickr
                        IMG_6853 by lawrx, on Flickr
                        I do still have some work to complete, the one roof panel on there is purely only screwed up there, not in its last resting place. need a hand to finagle it up there, kind of a pain being a fat over my head and 10 feet long.
                        IG @gt3_brz
                        My Mustang Build
                        My BRZ Build
                        My F100 Build
                        • Glad to see some updates, sucks that you couldnt redo the garage completely. I heard horror storries from guys at work about that in the same way. Bought a house with land and were promised that they could build a garage to only end up fighting with the township for months to have it not be close to what they wanted. Nice idea on the extra bump out for larger tools tho. Cant wait to see when you get some more time to keep working on it.
                          Insta Mintyhinrichs
                          • Originally posted by hinrichs View Post
                            Its hard right now with this whole COVID-19 pandemic. I am at work as i am considered an essential worker, and wife is at home currently full tie with kids as school and pre schools are closed down. Really only get 12 hours on a weekend at the moment. But progress is progress nonetheless. Once i have it fully closed in i will be able to continue working on electrical, insulation, and inside walls after work as wont be as noisy.
                            And yes, that was my fear, tear down what i have then be delayed, fully denied buidling anything at all. Not what i want, but better than the likely alternative of "trying" to start fresh. Ive taken some measurements and i will be able to make a 2 post JUST BARELY fit. Im excited.
                            IG @gt3_brz
                            My Mustang Build
                            My BRZ Build
                            My F100 Build
                            • Excited to see this grow out to a usable garage. It sucks to not be able to make it "the dream garage" but as pointed out, it might be the better option.
                              "You could roll an E30 in a BMW showroom today and people would think:
                              Well, they finally got the 1 series right!"
                              3.0 L e30 ground up build
                              • Some more work done on the garage. Prior owner had built a false wall in the back that needed taking down to maximize usable space. I also started clearing out behind the garage for the next addition. I will be allocating some space for an attached sectioned off shed which will be roughly 4.5x8. The rear garage portion will be an additional of 4.5x21. The back wall of the current structure i will remove the center beam, and run some 2x8 to really strengthen it back up and open it up.
                                IMG_6649 by lawrx, on Flickr
                                IMG_6650 by lawrx, on Flickr
                                IMG_6877 by lawrx, on Flickr
                                IMG_6829 by lawrx, on Flickr
                                IMG_6880 by lawrx, on Flickr
                                IMG_6882 by lawrx, on Flickr
                                IMG_6884 by lawrx, on Flickr
                                IG @gt3_brz
                                My Mustang Build
                                My BRZ Build
                                My F100 Build
