Yeeessss, TigFinger. Super awesome especially with pipe welding.
Project Crowdmower : Ford Chassis, Chevy Motor, and Nissan Transmission
Ive yet to actually need it. Although im sure i will, as to why i bought it. For as cheap as it was it was a no brainer since i saw already ordering things.Originally posted by sdistc View PostYeeessss, TigFinger. Super awesome especially with pipe welding.IG @gt3_brz
My Mustang Build
http://www.stanceworks.com/forums/sh...=1#post1552949
My BRZ Build
http://www.stanceworks.com/forums/sh...ad.php?t=86482
My F100 Build
http://www.stanceworks.com/forums/sh...ad.php?t=97329
Thanks bud. Actually the tig welder is my dads. Im just holding it hostage till he tries to rescue it lolOriginally posted by LCG View PostCongrats on the newborn, congrats on the tig welder...
question, what size rod did you buy for the tubing?
As for the filler rod its 1/16''. Its what my dad had on hand, not sure if its correct size for that application, am simply just trying ti learn the motions and such currently.IG @gt3_brz
My Mustang Build
My BRZ Build
My F100 Build
Some more practice welding. Ive for the most part got the technique down of using the filler rod. Ive now got to work on heat management, which part of my issue is torch angle, believe I have it laying back to far.
IMG_0097 by lawrx, on Flickr
IMG_0100 by lawrx, on Flickr
IMG_0102 by lawrx, on Flickr
Once I was to a point where I was confident enough to weld on a part I had spent money on I started prepping the turbo mounts. Theses mounts are made for several turbos so I had to enlarge the mount holes slightly.
IMG_0109 by lawrx, on Flickr
IMG_0110 by lawrx, on Flickr
IMG_0112 by lawrx, on Flickr
With them able to now be bolted up to the turbos I mocked up both turbos to measure the distance to cut some tube and welder-up!
IMG_0108 by lawrx, on Flickr
IMG_0105 by lawrx, on Flickr
IMG_0113 by lawrx, on Flickr
IMG_0115 by lawrx, on Flickr
IMG_0114 by lawrx, on Flickr
IMG_0116 by lawrx, on Flickr
IMG_0122 by lawrx, on Flickr
IMG_0121 by lawrx, on Flickr
IG @gt3_brz
My Mustang Build
My BRZ Build
My F100 Build
In case you bought the TigFinger without connection to Jody, his excellent YouTube channel "weldingtipsandtricks" has many, many, many wonderful hours of high quality welding instruction.Originally posted by laextreme5 View PostIve yet to actually need it. Although im sure i will, as to why i bought it. For as cheap as it was it was a no brainer since i saw already ordering things.
Ive yet to dedicate some time to watch his videos. Ive had numerous people refer me to his videos!Originally posted by sdistc View PostIn case you bought the TigFinger without connection to Jody, his excellent YouTube channel "weldingtipsandtricks" has many, many, many wonderful hours of high quality welding instruction.IG @gt3_brz
My Mustang Build
My BRZ Build
My F100 Build
Alright, continuing from the last update. Hit a bot of an milestone. Turbos are mounted and supported by their own weight! Finally felt confident with my welding to weld the mount I made to the chassis. Don't have much to talk about as ill let the photos do the talking. My son was out with me giving me a helping hand as well.
IMG_0124 by lawrx, on Flickr
IMG_0125 by lawrx, on Flickr
IMG_0126 by lawrx, on Flickr
IMG_0128 by lawrx, on Flickr
IMG_0129 by lawrx, on Flickr
IMG_0133 by lawrx, on Flickr
IMG_0135 by lawrx, on Flickr
IMG_0142 by lawrx, on Flickr
IMG_0143 by lawrx, on Flickr
IMG_0144 by lawrx, on Flickr
IMG_0147 by lawrx, on Flickr
IG @gt3_brz
My Mustang Build
My BRZ Build
My F100 Build
WOW!!! First time seeing this thread lol amazing work man, love stuff like thisMy BMW E36 318ti Steel Blue Compact build thread -
Turbo location looks awesome !My super boring build http://www.stanceworks.com/forums/sh...other-M3-buildInsta Mintyhinrichs
Thanks guys! ive got a bit more welding to do before i mock up the rest of the front end to see how it looks under its own weight.IG @gt3_brz
My Mustang Build
My BRZ Build
My F100 Build
Wastegates came in on Monday. Got to work making some tubes made up to fit. I will be doing a few pie cuts to reduce their angle off the main tube. Also fitted the front end for the first time since finalizing turbo mounting. Trimmed up the header panel to make room for the compressor to clock how I would like. And lastly I was sent a new set of coiler sleeves as my last set randomly seized up. Put the new ones on and set her on the ground to see how she looks with the turbos mounted.
IMG_0299 by lawrx, on Flickr
IMG_0302 by lawrx, on Flickr
IMG_0306 by lawrx, on Flickr
IMG_0240 by lawrx, on Flickr
IMG_0242 by lawrx, on Flickr
IMG_0243 by lawrx, on Flickr
IMG_0244 by lawrx, on Flickr
IMG_0294 by lawrx, on Flickr
IMG_0296 by lawrx, on Flickr
IMG_0297 by lawrx, on Flickr
IMG_0298 by lawrx, on Flickr
IMG_0305 by lawrx, on Flickr
IMG_0307 by lawrx, on Flickr
IG @gt3_brz
My Mustang Build
My BRZ Build
My F100 Build
That turbo placement just looks meanMy super boring build http://www.stanceworks.com/forums/sh...other-M3-buildInsta Mintyhinrichs
The plan is to get the compressor cover and wheel anodized/powdercoated in black for a sleeper-ish look.Originally posted by hinrichs View PostThat turbo placement just looks meanIG @gt3_brz
My Mustang Build
My BRZ Build
My F100 Build
