Originally posted by MikeyRa
View Post
My BRZ daily driver - Slow and Steady
Thats correct. as you press the upper or down button on the controller the motor turns and changes dampening same way you would manually with a knob.IG @gt3_brz
My Mustang Build
http://www.stanceworks.com/forums/sh...=1#post1552949
My BRZ Build
http://www.stanceworks.com/forums/sh...ad.php?t=86482
My F100 Build
http://www.stanceworks.com/forums/sh...ad.php?t=97329
Picked up some parts over the last few days.
Started collecting the rest of the parts for the braking system. Rear DBA 4000 rotors, stop tech stainless lines, Motul brake fluid, and Hawk pads are in. Front pads and front rotors are on order.
IMG_9310 by lawrx, on Flickr
IMG_9318 by lawrx, on Flickr
I also traded some alignments for some exterior parts. Got a TRD wing to replace the stock BRZ spoiler ( THAT I DESPISE) and some sit style side skirts. Fitment on both were great.
I also have on order the Cleib Dolphin tail 2.5" SS cutback. Cant wait for that to come in. Thats on a 2 month lead time so still have a ways out on it.
IMG_9308 by lawrx, on Flickr
IMG_9311 by lawrx, on Flickr
IMG_9313 by lawrx, on Flickr
IMG_9314 by lawrx, on Flickr
IMG_9315 by lawrx, on Flickr
IMG_9317 by lawrx, on Flickr
IG @gt3_brz
My Mustang Build
My BRZ Build
My F100 Build
Brakes, brakes, and more brakes.
Front rotors arrived the other day. Fantastic quality, made by Compbrake. The original 1 piece rotors to fit this kit are no longer available, therefore a few companies have made a 2 piece setup to fill the market gap. Only issue with the kit was i was missing the nuts to bolt the disc to the center bell. Once they were in a mocked the kit up on the front as i still qasnt 100% positive they would bolt up. The Bombsquad performance bracket i had replicated out of T6 aluminum vs the original steel worked flawlessly, along with the rest of the components.
IMG_9324 by lawrx, on Flickr
IMG_9325 by lawrx, on Flickr
IMG_9326 by lawrx, on Flickr
IMG_9327 by lawrx, on Flickr
IMG_9328 by lawrx, on Flickr
IMG_9329 by lawrx, on Flickr
IMG_3787 by lawrx, on Flickr
IMG_3788 by lawrx, on Flickr
IMG_3789 by lawrx, on Flickr
IMG_9330 by lawrx, on Flickr
Also partially disassembled the front calipers, to get them ready for install. Removed the adaptor bracket, removed the pad bolt, the brake line bolt etc. That way they are in a readily state to be installed.
IMG_9471 by lawrx, on Flickr
IMG_9472 by lawrx, on Flickr
IMG_9473 by lawrx, on Flickr
IMG_9474 by lawrx, on Flickr
IMG_9475 by lawrx, on Flickr
IG @gt3_brz
My Mustang Build
My BRZ Build
My F100 Build
Well car is temporarily down. Thursday coming home when getting off the interstate car developed a severe misfire. Last 3 miles home had blinking CEL and then solid CEL. Ive determined it to be what I believe a bad coil pack. Cars never een tracked and I rarely beat on it enough to build up substantial heat in the engine bay. In the process of testing to figure out the issue I killed my Braille battery. Showing 12v but won't crank the car over. Wondering if that may have also contributed to the issue. Will find out soon enough when the new parts get here.
IMG_9476 by lawrx, on Flickr
IMG_9584 by lawrx, on Flickr
IMG_9596 by lawrx, on Flickr
With the car down I decided to take advantage and get a few things done I needed to. Pulled the Volks off and washed them up, installed the new authentication stickers, and going to get them ceramic coated.
Also fixed the EDFC wiring that got damaged from not having the strut stoppers installed.
Also installed the stut stoppers so I could finally hook up the EDFC. Once cars back up and running she should be good to go.
IMG_9578 by lawrx, on Flickr
IMG_9579 by lawrx, on Flickr
IMG_9580 by lawrx, on Flickr
IMG_9585 by lawrx, on Flickr
IMG_9586 by lawrx, on Flickr
IMG_9587 by lawrx, on Flickr
IMG_9589 by lawrx, on Flickr
IMG_9590 by lawrx, on Flickr
IMG_9591 by lawrx, on Flickr
IMG_9593 by lawrx, on Flickr
IMG_9595 by lawrx, on Flickr
IMG_9599 by lawrx, on Flickr
IMG_9600 by lawrx, on Flickr
IMG_9602 by lawrx, on Flickr
IMG_9603 by lawrx, on Flickr
IMG_9615 by lawrx, on Flickr
IMG_9619 by lawrx, on Flickr
IMG_9616 by lawrx, on Flickr
IG @gt3_brz
My Mustang Build
My BRZ Build
My F100 Build
Alright so coilpack wasnt the issue. Spoke to a few locals and figured it to be the DI injectors. Earlier this week i disassembled it, pulled everything out. Cylinder 3 is what the code came back as......And it had the best looking seal, which kind of baffles me but ya know what if seals fix the issue fantatsic.
IMG_9770 by lawrx, on Flickr
IMG_9769 by lawrx, on Flickr
IMG_9772 by lawrx, on Flickr
IMG_9771 by lawrx, on Flickr
IMG_9773 by lawrx, on Flickr
IMG_9774 by lawrx, on Flickr
While waiting for the seals to arrive i set everything out for the brakes as iw ill be installing them very soon as well. Front rotors needed to be assembled as well. Wanted to make sure i had every component that i needed on hand and ready to go.
IMG_9775 by lawrx, on Flickr
IMG_9777 by lawrx, on Flickr
IMG_9778 by lawrx, on Flickr
IMG_9779 by lawrx, on Flickr
IMG_9781 by lawrx, on Flickr
IMG_9783 by lawrx, on Flickr
IG @gt3_brz
My Mustang Build
My BRZ Build
My F100 Build
Just an update. Cars is still at the dealer. They are still diagnosing.
In the mean time i did a widebody install on a local twin, had some money burning a hole in my pocket and ordered a few parts.
Exedy Chromoly lightweight flywheel, Exedy OE replacement clutch, and an IRP short shifter. Now all i need to do is drop my trans off at my local shop abd get the new carbon syncrhos put in.
So current list of parts to install when i get the car back now consist of.
-Prodrive BBK
-Cleib catback (suppose to be stateside early May)
-IRP Short Shifter
-Trans with Carbon Synchros
-Exedy Chrom. Flywheel
-Exedy OE clutch
-Defi STI Genome Oil pressure gauge
Should drop about 30lbs with those parts.IG @gt3_brz
My Mustang Build
My BRZ Build
My F100 Build
so is the long term plan to just keep it stock body and focus on track performance?
not saying I want you to go "widebody" with flares, cause I dont, but if you do, please for the love of god. DONT. DO. ROCKET. BUNNY.
Too many cool kits out there for the BRZ/FRS.
Instagram: @half_lung
Im really not sure at this point. Main focus is just making it more fun to drive. No particular goal in mind. I have the centerlock TE37s i purchased last summer, which if i go widebody will be wheels i use. And no, it will not be rocket bunny, it will be the VAris kit, with some of the Kamikaze parts thrown in and some additional modifications to the kit as well.Originally posted by scweet14 View Postso is the long term plan to just keep it stock body and focus on track performance?
Too many cool kits out there for the BRZ/FRS.IG @gt3_brz
My Mustang Build
My BRZ Build
My F100 Build
Got an update from the technician over at Subaru. They verified coilpack, spark plug, and injectors. They found an issue with the injector control module. They changed it and it ran over ok for a few minutes, however issue still persist.
The claim has been escalated up to get an Subaru engineer involved. They are thinking some form of Voltage issue. Due to the amperage the Di injectors run the tech is unable to check it.
So at this current point in time we are simply awaiting to see what the Engineer finds and go from there.IG @gt3_brz
My Mustang Build
My BRZ Build
My F100 Build
Suggest they monitor the injector pulse width with an oscilloscope if they're scan tool has provisions for it. Sometimes the CAN-BUS has provisions for it so they can monitor voltage without the risk of a tech incorrectly installing or using an additional peripheral. My buddy at a Kia dealer usues it all the time to pinpoint DI gremlins.
-1993 535i/5 NA-T
Im going to let them do what they need to do. Have trust in the guy working on my car and that they will do what is necessary to remedy the issue.Originally posted by CSBolger View PostSuggest they monitor the injector pulse width with an oscilloscope if they're scan tool has provisions for it. Sometimes the CAN-BUS has provisions for it so they can monitor voltage without the risk of a tech incorrectly installing or using an additional peripheral. My buddy at a Kia dealer usues it all the time to pinpoint DI gremlins.IG @gt3_brz
My Mustang Build
My BRZ Build
My F100 Build
Update on the situation.
Issue was found to be in the shortblock. Plan was to wait for a new shortblock to arrive and drop that in. Get a call from my friend who is the tech working on the car with some news. Shortblocks are on backorder. SOA has given him permission to tear down the motor assembly to find the issue and see if it is repairable.
Come yesterday he texts me and gives me the down low. cylinder 3 piston is warped, there is a decent gap at the bottom you can see if you look closely (cant see in pics he provided) and the cylinder looks like an egg. So block is bad and we need to continue waiting for the shortblock as originally planned. Currently still do not have an eta as to when that will arrive.
IMG_3484 by Cody Rinaudo, on Flickr
IMG_3483 by Cody Rinaudo, on Flickr
IMG_3482 by Cody Rinaudo, on Flickr
While i wait ive been knocking some things out ive wanted to do while also collecting some parts. My tob makes noise at idle and i figured it was a good excuse to upgrade to a lightweight flywheel and new clutch. Its an Exedy OEM replacement clutch and their lightweight flywheel. believe the weight to be 11lbs if i recall correctly. About half the weight of oem. My exhaust also came in, its a cleib 2.5'' SS catback. Welds are SUPERB on it. I cant wait to hear it. I also picked a header, over pipe and front pipe which will be here later this week while i am out of town. I also opted to put some Tredwear tire letters on my tires. Figured id try it out and see how i like em. ANd lastly, with the wheels off the car and the catback here i had a buddy come by and tried our hand at ceramic coating. Also put it on the calipers, gotta make them purty things easy to clean.
IMG_0919 by lawrx, on Flickr
IMG_0920 by lawrx, on Flickr
IMG_0921 by lawrx, on Flickr
IMG_0922 by lawrx, on Flickr
IMG_0923 by lawrx, on Flickr
IMG_0924 by lawrx, on Flickr
IMG_0925 by lawrx, on Flickr
IMG_0926 by lawrx, on Flickr
IMG_0928 by lawrx, on Flickr
IMG_0937 by lawrx, on Flickr
IMG_0938 by lawrx, on Flickr
IMG_0939 by lawrx, on Flickr
IMG_0940 by lawrx, on Flickr
IMG_0941 by lawrx, on Flickr
IMG_0942 by lawrx, on Flickr
IMG_0945 by lawrx, on Flickr
IMG_0946 by lawrx, on Flickr
IMG_0947 by lawrx, on Flickr
IG @gt3_brz
My Mustang Build
My BRZ Build
My F100 Build
