Static 1990 Daimler Six
  • Static 1990 Daimler Six
    Hello!
    My name is Joakim, from Sweden.
    Last year I bought myself a Daimler Six. It's the same car as a Jaguar xj40, but fully equipped with all the luxury that was avalible at the time.
    Then ordered some cheap wheels and cut springs.
    Luisi steering wheel. Actually bought it with hub and all before I bought the car..
    Then some spacers up front. 28mm
    I am going to build a custom set of coilovers since there is nothing but lowering springs avalible for this car to buy.
    This is BC racing springs 10kg/mm and adjuster for Volvo 740 rear. These will be mounted up front with new seats for it. Don't know yet if the damper will bottom out. In that case I will run some shorter shocks as well.
    In the rear I will run AVO universal coilovers with modified top mounts.
    New wishbone bushings are ordered and will show up in a few days.
    Since I dont have a garage that will fit a car I have to wait for the snow to melt to get the car out.. But it will only be a few weeks
    Nice car, great colour combination. Hope you don't overdo the car, it has a natural elegance to it as it is now. Imho anything much past wheels and a drop is unnecessary in my opinion.
      Unique cars are always fun, keep it up
      Instagram- slow_316
        this is cool man
          Great looking platform.
          some decent wheels would really set this off.
          i shouldn't be daily driving this:
          "Volkswagen Golf mk1 build thread"
            subscribed!
            2001 BMW 560i 6.0 LSx/T56 SOLD
            2000 Corvette Hardtop FRC
              Thanks guys!
              Yes. I would love a set of split wheels, but I'm trying to keep the costs down since my main interest is in my bikes.. But hopefully I will not be ashamed when rolling around in this thing in the summer.
              So.. The car came out of the snowy backyard. Got to work right away
              Removed the rear cambershims completely from the driveshafts and put my front spacers in the back. The wheel is now 17x10 et-13.
              Rolled the fenders and removed the original strut. The car sits on factory bumpstops, but these will be removed once the coilovers is in place. So hopefully this will be my rideheight + maybe 5-10mm. Rimgap is at 15mm.
              This is how it came out:
              I'm pretty pleased with the fitment. Now I have all the measurments to order som coilovers in the back. Next weekend I might start on the front suspension
                Super cool, can't wait to see more of this
                @sirlowalot
                  This is sooo wicked
                  2002 Infiniti I35 ( 6 speed swap in progress )
                  2004 Nissan Maxima SE 6 speed ( Closest car to being "stanced" )
                  2003 Nissan Maxima SE 6 Speed
                  2002 Lincoln LS
                  On the verge of being Stanced
                    can't wait to see the front. can you explain more about those shims? do they space out the axle/wheel?
                      if i was you i'd stick with wire/mesh wheels
                      Floccinaucinihilipilification
                        damn, you can't go wrong with big body and mesh wheels,can't wait to se fronts too, but I like where this is going ,maybe a little more camber to the rears and thats it!!
                        Previous build http://www.stanceworks.com/forums/sh...ad.php?t=72315
                        current build
                        http://www.stanceworks.com/forums/sh...highlight=w124
                        follow me on IG @the.papandopulo
                          fan va frän då
                            The jaguar irs suspension uses the driveshafts as upper control arms. By removing or adding shims to the hub by the differential, you can adjust the camber.
                            It's easy to see how it works in this pic. Not mine, but the irs suspension that they put in a capri or something.
                            My camber is maxed out now in the rear. I could remove and mill(?) the hub a few mm, but I think its enough as it is.
                            Originally posted by spaaals View Post
                            fan va frän då
                            Tack du
                            Today I ordered the rear coilovers. I went for 16kg/mm or 900lbs springs. Hope it will do..
                            Bonus:
                              Nice car!
                              @ plus!
                              Chris
