I honestly dont know where to start lol........
here are pics
After loads of rust and learning how to weld, I semi-completed the car in Jan-Feb w/s52 swap, It was fun for a bit. I even took it to auto-x and did well for my first time out on the car.
Long story short, the car still needed more work. I have decided to strip the car down and attempt to go for something different.
So the flares are going
everything else is going....
I got new meat...
I got a wrecked ap2 s2000 that will be my donor for suspension and engine.
Started cutting away and taking measurements
healthy f22c low miles six speed
[IMG]
[/IMG]
rough stages still. the gloss black point is just KBS rust seal.
Note, interior paint is temporary. Its just to prevent temporary rust.
in a nut shell.....
the
car
is done....
but i still got to tiddy up some things
-windshield nozzles not installed
-install passenger door window
-install door seals
-figure out the rattling from the doors.
-Va state inspection which i will have it ready to pass
-install stiffer springs currently the car has 400 front and 325 rear but ill explain more why i am changing these.
-clean up the wiring inside
-eventually get the electronic power steering to work
-enjoy the car for the 2016 race season
First auto x Feb 28 NASA event at VMP
On Feb 20th I went to my favorite shop PTuning in Manassas,VA for a corner balance and 4 wheel alignment
the final result for my corner balance with a 200 lbs ballast for driver
LF 703 lbs RF 636 lbs
LR 727 lbs RR 664 lbs
Cross 49.93%
Car weight w/o driver 2530
Car weight w/ driver 2730
the car has 49/51 weight distribution which caught my off guard. I really wasn't expecting that.
The car also surprised me with the weight.... I was really hoping to be at the 2000-2300 mark.
But I think I can figure out how to shed more weight my ideas are
-rear lexan windshield
-rear quarter windows lexan
-driver and passenger windows lexan
-Fiber glass hood and trunk
-light weight battery
-aluminum front fenders?
- lighter wheels? lol idk
These are my alignment specs
Front Right Left
Caster 5.8 5.8
Camber -2.7 -2.7
Toe 0 0
Rear
Camber -2.4 -2.4
Toe 1/16" 1/16"
onto the pics....
rear exhaust utilizing e60 bmw oem muffler, and vibrant resonator at the end, I really didn't want to make this car super loud.
here are pics
I got new meat...
[IMG]
[/IMG]rough stages still. the gloss black point is just KBS rust seal.
in a nut shell.....
the
car
is done....
-install door seals
Cross 49.93%
Front Right Left
Caster 5.8 5.8
Camber -2.7 -2.7
Toe 0 0
Rear
Camber -2.4 -2.4
Toe 1/16" 1/16"
onto the pics....
