Hello all,
My other project (1.8t MK1) is on the backburner because this C32 has stolen my heart.
I bought the C32 with some engine problems but have since resolved it (see below if interested).
Along with this, I replaced the Supercharger pulley bearing and spark plugs.
First modification was changing out the wheels with another exact same size AMG because the previous owner's tires were going bad. :rolf:
After that I bought some 18" Brabus wheels, but still wasn't feeling it.
Recently I did transmission flush (I could do a DIY with videos, but saw others have done a flush) and the car runs great.
Nasty old transmission fluid:
New stuff (meets Mercedes Specs and is only 18 dollars a gallon at Walmart :bow
I realized that the car needed to be lowered and the current wheels weren't cutting it so I picked up a set of VXS910 wheels and a brand new set of BC coilovers.
Wheel specs:
19x9 Front +35 offset
19x10 Rear +47 offset (now 35mm with a spacer)
5x112 Lug Pattern
66.56mm hub bore
BC Coilovers:
Going to space out the front by about 10mm and move the 235 rear tires to the front along with purchasing some 255-265 for the rear. Hopefully some more updates to come soon once I get the spacers and clear the perch.
Only picture I took during the install.
Wheel specs:
5x112 Lug Pattern
66.56mm hub bore
BC Coilovers:
