More things!
Came back the next night to the shop to start cranking away on pulling the current suspension bits. Started off with a tiny job to get me warmed up.
Swapped out the standard bulbs for LED bulbs, didn't really do shit except make it a little brighter. Oh whale
Air Ride Install @ Salt City Auto Styling by David Arellano, on Flickr
THEN I swapped out my license plate bulbs for some MUCH brighter LED's and holy crap did it make a difference!
THEN it was time to really get started. Started off in the rear pulling the LCA's off. I was amazed to find virtually no rust whatsoever under the car. Every bolt came out just as it should from factory.
The rear shocks were completely toast!
Old vs. New - These are the Saab KYB's purchased from Rock Auto, still not sure if they're short enough so I may end up going with the Ford Ranger front shocks eventually. These bolt right up!
Old camber arm vs. new adjustable DIY unit! You will have to run a larger diameter bolt with new washers and nuts. Unless you want to pound out the sleeve that sits in the OEM arm and hammer in to the new one. (which isn't worth it in my opinion.
Front suspension before
Little bit of a difference here - OEM vs. Only Charged Dubs kit
Old massive springs!
Old shocks vs. new coilovers! Reminder: These are E36 coilovers (Raceland in my case (only because I got a package deal with these, camber plates and camber arms))
Mookeh camber plates which were custom drilled for the 190E platform. They fit perfectly!
New LCA installed!
So that was a checkpoint over two nights. Have to give a huge shoutout to a few friends that came by to lend a hand and help me get this taken care of. Without their help it would've been quite a bit more difficult to get it all done.
New LCA installed!
