Cougar House Garage Project Sacrilege Ford Super Duty
  • These came in this morning side marker and running light I got the LED's from superbrightleds.com
    Heres the harness that runs to the back of the truck fuel tank sending unit, tail lights and trailer lights
    Website: http://cougarhousegarage.com/
    Check Out Our Facebook Page For More Pics and Videos
    • Old 5.9 dip stick tub
      New one installed
      • $$money$$
        Pronounced Eve-odd Rich-E
        • you betcha dog
          • Next up we did the 2008 5R110 large trans filter and matching pan upgrade were going to be pulling a 24' Edge race car trailer for the drift cars with it now
            I'm going to build it a trans skied plate
            Earl's 8-AN weld fittings to be TIG welded to the trans cooler
            Weld fittings TIG welded on and the trans cooler reinstalled on the back of the intercooler
            Miked up perfect
            • Ordered this through Amazone Max Tow by Glow Sport gauges to monitor the tank presser in the cab
              I'm going to install it were the 4WD switch went
              • I'm going to use this liquid filled gauge I got though Amazon to monitor tank presser on the tank itself
                • I received these through Amazon to connected the fuse box's then to run back to the battery
                  Passenger side cab fuse box
                  Driver side to engine compartment fuse box
                  • Soldered in the LED drivers
                    Don't need this
                    I think they look great to tell the projector retrofit
                    • That light beam is intense, you guys arent messing around out there. Incredible project.
                      l ig:coltondk l youtube:coltondk I DD: Tundra I Projects:l 06 STI I 87 S10 l I 57 Chevy Belair I I 48' International KB-2 I 07R6r l
                      • Is this going to be at the leavenworth drive? :x
                        • Originally posted by drifte View Post
                          Thanks man your cars really nice as well
                          Were going to try to make that event
                          • Made the shelf for the fuse panels to sit on today
                            Mount the Accuair ECU on the end
                            Made a hole for the bussman fuse,and relay box to mount and the 70amp relay will go here
                            70amp relay mounted
                            Redid the compressors grounds
                            I made grounds with male and female plugs so I could plug them in when I'm installing the self.
                            These females will bolt down for the ground males to plug in to.
                            I like using white for ground
                            • Lets connect these batteries
                              Boom
                              Power side
                              Getting the self installed
                              Installed the maga fuse block
                              I ran the 10amp 12+ Accuair fuse through the bussman fuse box
                              Got my last delcity order organized
                              Stinger 250 foot spool of 4 gauge wire
                              • Clean wiring like that makes me happy.
