Originally posted by gearheaded
View Post
E34 540i/A DD
spacers arrived i think 15mm for front was a bit to much although the inner part of the rim now clears the shock they stick out to much. i think i could manage with 10mm
original et20 7.5"to new et24 9"
this pic is up on stands so top is out more than it would be on the floor. plus tyres are to big and touch the spring cups.
so fitted original wheels. they touch so need the spacers and it needs raising slightly as tyres will rub on lock. car just needs dialing in and correct spacers and tyres, getting there slowly
also did single stage compound on bonnet to try new detail set
before with swirls
after first stage
hi mate.yes thats probably the one its been on there a few times i think. hadnt been used for a yr!!Originally posted by Matt_Slater View PostI'm sure I spotted this on EBay, was going to take a punt at it but ended up with an E38 v8 instead,
I've also bought BC's for mine but the front doesn't go anywhere near low, a bit pissed off about it really lol.
thats odd i thought the shocks would be very similar is it a complete coilover or a sleeve setup?Last edited by jimmk1; 03-31-2015, 02:23 PM.
your previous sound cool, im pleased with it i dont even mind it being an auto
i can understand the rears being a bit harder to get low cause correct me if im wrong aren't they separate spring/shocks? have you bottomed out the fronts?
(ignore this just read your thread in coilover section. haha complete oposite of what i said^^^^)Last edited by jimmk1; 03-31-2015, 02:44 PM.
only thing i can suggest is email bc north america, i spoke to a guy called scott clifford from there tech team he was very helpful. he might be able to throw a few suggestions your way.
i guess if the lb rating increases on the spring you might be able to spec a shorter spring overall,
dont speak to apex here in the uk i found they arent worth the call?
front tyres fitted 235/35/19 with 15mm spacer.
I need 5mm spacer for the rear as tyre is slightly touching shock! rears are currently 255/40/19 gona run these for a bit. then change them at a later date possibly to 245/35/19
suspension still needs to be dialled in as the whole car can go a lot lower.
