Z32 project, "six month build"
  • The DET and DETT are quite different engines whilst being very related. Think of the DET as the less complicated cruder older sibling of the DET. The DET uses the resonance intake affect to it's advantage and is pretty complicated from an airflow perspective, but very beneficial in the mid/top end for power. The piping would get really confusing if you decided to stock DET dual TB's facing the right side and have the intercooler piping for the left side turbo wind around to the other side of the engine. It might be best to combine the intercooler piping and have it split off on the right side. I would love to see the DET plenum on the DETT.
    𝔣𝔬𝔩𝔩𝔬𝔴 𝔪𝔢
    @𝔳𝔦𝔳𝔢_𝔪𝔢𝔪𝔬𝔯_𝔩𝔢𝔱𝔦
    • very interesting idea for your plenum, builds like this are rare among the z32 community
      • Nice build you have here. I particularly like the chassis bracing. A large number of people don't pay attention to chassis flex on these 90's cars, and it can pay large dividends in handling and ride quality.
        On the plenum subject: The Cima plenum doesn't flow as well as the J30/Z32 plenum. Nissan redesigned the plenum specifically for the DETT engine, and the "new-style" plenum is less restrictive. However, if you're going to fabricate a plenum from scratch to attach to the lower intake manifold, it seems like the Cima plenum would be advantageous, as the port configuration lends itself better to a simple plenum design.
        I'm not sure about the way they line up, I'd imagine they fit the '89-90 heads, but as of the time of me writing this, I am unaware. Time to do a little searching.
        • Hey. I ended up on your thread on jdmstyletuning and realized the Carbing strut tower bar I picked up is really similar to the one you've got (except for the GC8). I'm a fan. I **** flimsy/thin/adjustable STBs.
          • Originally posted by rice4life View Post
            I'm not really keen on the DET plenum. To be honest it just looks like a cheat of a way to keep each bank receiving roughly the same volume of air despite being fed from one side only. Both banks are completely split with a valve on top that presumably opens at higher RPM to help balance the pressure between the two. Wouldn't be necessary if it was symmetrical.
            thank you. you know the pains of fitting a single intake - I am trying to avoid having a kink straight off of the stock lower plenum going to vertical runners. to be honest the DET lower plenum looks like too much work to fit to the DETT heads - doable, but will require major head gutting and then weld build up to make it happen. I might just get the DETT lower plenum milled down an inch or so then weld custom runners to it to make the whole process simpler. I'm considering then mating those runners to one of these - the dimensions seem ideal for hood clearance.
            Thanks for the kind words and welcome to the forum. Unfortunately the DET lower plenum doesn't fit any generation of DETT heads. Because the runners are so much shorter and both generations of runners funnel, the DET runners taper in closer to the valve. They are much larger when lined up with the DETT head ports.
            Nice find there. Most of the carbing stuff I see is aluminium like yours. My bar is old school heavy steel. Good in my case since the design is so convoluted, but alloy is preferable most of the time.
            • With the fitting of my seats I gave my car a proper clean out of the interior which after more than a year with the roof off while I did (bay) bodywork was sincerely needed. After clearing all the shit out of it and vacuuming it hard enough to suck a golf ball through a garden hose it's looking tops especially with the painted rear brace. Before long trashed interior withdrawl symptoms kicked in and that happened;
              The next project was more or less a total rear end overhaul. This means fitting the rear bar properly (some modification required), extensively modifying the diffuser (read: cutting the shit out of it), making a new boot floor, making a path for the new exhaust system and relocating the fuel tank. Regarding the latter, here's why:
              Fuel tank in black, diffuser grey, bumper blue and red the underbody line of the car. The diffuser, a "generic" item from Ab-Flug, doesn't fit the 2+2 Z32 very well. The trailing end of the fuel tank fouls on it, and forces the leading edge of the diffuser to jut down towards the road. With a bit of measuring it seemed like with the tyre well out of the equation there would be plenty of room for activities. The factory space saver spare wheel won't clear my brakes anyway.
              With the boot floor cut out rail to rail I jacked the fuel tank up to where I wanted to put it.
              It looked like the tank was made to be moved - the contours of it align perfectly with factory reliefs in the frame rails further forward in the chassis. I did in the end have to give it a bit of a love tap here and there as a few portions of it were sticking up above the boot floor.
              Bolting it up in its new location was actually really easy too. Original straps with original brackets, trailing ends rotated forward and drilled out in an unused OEM hole already in the bracket. The straps then bolted up to the factory mounts with factory bolts.
              I blasted the hell out of the tank with a high pressure hose, repainted it with new sound deadening, epoxy'd on the OEM isolation rubbers on in new their new locations and stuck on some rubber pads to the high points.
              The old boot floor can be used as a gauge for how far forward the tank has been moved. Bit better weight distribution is an unintended plus I guess.
              If you look closely in the above pic you can see that I cleared an area of sound deadening around the new hole of dead flat sheet metal. That's so the new aluminium floor panel can bolt down flat against the frame rails with a weatherstrip seal. I put in a daisy chain of nutserts to secure it.
              With the tank out of the way I could move on to the party piece - the Ab-Flug carbon fibre diffuser. Now just because I could actually align the leading edge of the diffuser with the under body doesn't mean I was done with it. As you can see here, the generic unit doesn't fill the whole underside of the bumper area. Panel gaps aren't cool on properly sorted street cars and I'm not building a race car. Aside from the sides it also protrudes past the bumper when bolted up in the same manner the previous owner did.
              I don't care how JDM tyte your car is it's got ****ing gaps in it. Not slick. Que the chop suey.
              With a solid game plan in place I measured up some cut lines using my super magnets to flex a ruler topside the panel.
              This was really one of those grit your teeth and don't be a skeptic moments...
              I picked up a slip roller and got to work forming some sheet metal to widen this thing.
              With two 15 cm aluminium sections to go in I needed a set of brackets to hold the thing together. I deliberately chose to keep the diffuser a five piece rather than glassing together the whole thing, but that won't come into play 'til later.
              I'm getting better at knocking up bracketry and this was a real quick deal all drilled and shaped together, then nutserted.
              I wanted to avoid hacking off the lip on the trailing end of the diffuser and simply tuck it into the bumper but unfortunately it just wasn't going to work.
              With the width where I needed it to be I set about properly mounting the diffuser. First to the bar, this time with no edges sticking out.
              As far as fixing the diffuser to the car, the process was layered. While this is no CFD analysed race car, for me to go to all this effort I want the diffuser to have at least a chance of functioning. First step was lining up the leading edge to the lowest point of the underbody, which meant ordering in the long on-the-buy-list Ultra Racing four point rear underbody brace from the last update.
              With the height set I made the brackets up from 3/4" box section. This was a pain in the ass as there needed to be ample room to plumb the twin exhaust through there as well as clear the fuel tank. I weighed up a few options including on the the fuel tank straps as well as simply one long wide bracket (that would've been great). Running down from the frame rails via the subframe was the only no-compromise option, and the car had just enough space to do it. The subframe is getting solid mounted down the track so there'll be no flex issues.
              Both far edges got mirrored brackets to the chassis too.
              Feels solid as all hell. The brackets are definitely strong enough to hold me up, the diffuser maybe not though. Lining up these things dead even was a battle.
              I cut out a new boot floor out of sheet. Much better access to the fuel pump in the long term which is sweet.
              Next up was working out the fin situation. The diffuser came with a pair, which was nowhere near enough with the new width. I was quoted for new fins and the price was just silly, and I wanted to change up the design a bit anyway. After a great amount of digging for a supplier I picked up some preformed 10mm fibreglass plate and went to town.
              The curves were very difficult to match and each one is slightly different. I went through a few ideas how to mount these, but after cutting them and feeling how light they were I went with the method that meant the least further diffuser decapitation (because you know, it's basically as new right).
              Four M4 rivnuts epoxy'd in to each fin hold the four on.
              Fit up. Starting to get an idea of how the setup will look.
              It was about now that I realised I had big problem that I seriously didn't see coming. The diffuser actually hangs lower than the rear bar.
              Trying to make an aero part that could actually work has its draw backs. After some good pondering of this honey doodle I worked out a plan for the outer fins to fix the situation. They cap either end of the diffuser and extend up to inside the chassis.
              This unfortunately meant seriously modifying the double D mounting brackets I had already completed, which I can assure you I was stoked to have to do.
              Now I have double Bs. The outer fins bolt up flat to one of the faces of the brackets as so;
              With the fins all shaped up all the fabrication was at long last god damn over. Cue the paint prep, priming and me calling it a day.
              I glassed over all the excess holes and filled up all the chips, scrapes and chunks from the previous owner. And a nearly full length cut I made in the centre section before realising I was an inch out from where I needed to be. Dickhead.
              The primer work didn't come out hollywood perfect but I don't really give a shit. Good enough before a pro can finish it.
              I was actually glad to cover up the carbon. I **** carbon for carbon's sake when it's just cosmetic. Carbon is cool when it's there because it's strong and light; not just slathered on as a final coating for looks. Unfortunately that's what the diffuser is; fibreglass underneath. The only thing that stopped me ripping off the whole carbon outer layer was the amount of smoothing out I'd have to do afterwards. Besides, the aluminium sections were never going to tie in properly otherwise.
              I borrowed a router from a buddy of mine and rounded off all the edges. The bolts on the outside fins were also countersunk.
              A small pair of riveted on brackets hold up the trailing ends of the outer fins.
              And there you have it, done and dusted.
              If I'm honest, this project was brutally time consuming and difficult. It is a perfect example of something just taking way too long and by the time I threw the last bolt in I wasn't satisfied so much as I was ready to set the thing on fire. The amount of cutting, shaping, measuring, doing over and even just time spent simply staring at different portions of the vehicle trying to conceive solutions was vexing to the nth degree. A wise man once told me to do one thing until it's finished and I'm glad I did because there were a number of times with this project when I thought I could see the light at the end of the tunnel, only to keep on and realise there was weeks and weeks of work left.
              But the end result is something pretty cool. Maybe when a couple of months have passed and I've forgotten the amount of work in it I'll dig it more. Or when I have the car further forward in the garage allowing me to properly take it in, haha. Then I think I'll go about replacing the epoxy'd nutserts in the fins with full length stainless bolts; one of them has already pulled out as you can see on the trailing end of the passenger side centre fin. urgh.
              Time to finally move onto other enhancements. At long fucking last.
              - A
              • Ow man that execution is brilliant!
                and the hangers are awesome.
                I actually read the text on some threads and this is one of them ...
                Fuel tank in red, diffuser grey, bumper blue and red the underbody line of the car
                the fuel tank is black, or a very very VERY dark red...
                • fuck looks awesome!!!
                  Passion Garage
                  http://www.voomeran.jp
                  • thanks guys I'm glad you like it. and I like the odd compliment about reading the thread, it's a good point! I'll make that correction, I proof my posts but this one was pretty long and it was getting late when I was polishing it off.
                    • Garage is a bit too tight for my DSLR lens, but the camera phone can take in the new rear end setup a bit better. Sorry about the quality.
                      • absolutely love it!
                        Instagram - Benwalsh91
                        • Some people will never understand it, why we do what we do.
                          The busted knuckles and the late nights in the garage;
                          it's more than a hobby or pastime, it's a lifestyle. We live it."
                          Instagram: @Stance_God
                          My 93' EG Sedan Build ( Daily )
                          My FC3S RX-7 Build
                          • thanks fellas
                            • I am currently off for a few weeks between semesters and have had time for the car. Second half of semester is always a killer, but I did very well so it was worth it.
                              I'm also doing a big tear down on my daily 675 Daytona. I started riding it a two or so months ago and it's stock as a rock. Nothing mental, just needed the usual; remove unnecessary factory crap, regular bolt ons, odds and ends then tune. Then put it back together and never throw spanners at it again (touch wood).
                              No big content post on the Zed yet, but one is in the works. I'm doing the front tubs and am probably nearly half way through.
                              In the mean time though I did polish off a tidy up job on my cluster.
                              Here's how it used to look:
                              And now:
                              The difference is with the GReddy. I wasn't keen on the double screen and different ring, so I had the gauge disassembled and sent the cup off to a buddy to have him lathe it down to clear the cluster ring from the set I already had. Sprayed the inside of the gauge cup black so it didn't show and now it looks nearly OEM.
                              - A
                              • awesome build dude. I didn't realise there were people who loved rare 90's jdm parts as much as I do! so many cool parts and a huge effort on your part. Well done.
