1969 Mercedes-Benz 250 W114
Sorry to hear=( Glad the e21 can be saved and that you found this
Ooooooo this is going to be fabulous
Mx73 Cressida Build check it out!
http://www.stanceworks.com/forums/sh...ad.php?t=59875
Ig: Japetto516
this should be real cool, was gutted to see what happened to the M3, hopefully this fills the gap in the garage and gets your mind off it.Bagged E46 saloon/sedan build thread --->>> http://www.stanceworks.com/forums/sh...ad.php?t=55964
Instagram: thomwilliams_
I'm disappointed in my self for missing this thread haha
Its been a while but here is a small update.
Car went in for its Mot which uncovered a lot of work that needed doing just to get it on the road which I did expect but not quite so much.
Some of the bad bits that I got pictures of.
While the car was getting the work done I started ordering parts ready for when I got the car back.
First was some nice new split rims that I wanted before anyone else did on one of these W114.
Mercedes Barock wheels made into 3 piece splits.
Test fitting showed that I would need to space out quite a lot.
So I ordered these H&R 30mm spacers.
These were perfect for the fronts but will need bigger ones for the rear which I will order once the airride has been fitted just in case I go out to far.
Then I got some tyres fitted.
Fronts.
Rears.
I also picked up a cheap headunit for now on eBay, which I will upgrade to a becker one at a later stage.
Then I found a rear window blind on eBay also which I just had to buy.
And then ive had this AA badge at home for as long as I can remember which I also to add to the front grille.
Then to top it all off probably the coolest things ive ever bought.
White Walls.
Fitted.
Please ignore any of the bad bits of bodywork you can see as I know is it a state at the moment, once back from having its airride fitted it will be going into the bodyshop for a full make over.
Last weekend when I dropped it off at Studio Incar.
More updates soon.
Instagram - WOODYM3EVO
Studio Incar have a flawless record of absolutely flawless cars. I haven't got the slightest doubt that they'll make this look amazing
Watching! THose whitewalls look good on there!-Christian.
