Those fender wells came out so clean. I would say go with BC racing coils just from experience. Car is off to a good start for sure.
My bronzitbeige metallic e28
Yea I was gonna say the same , Makes me want to go outside and scrub the hell out of my wheel wells . I'll add that to spring cleaning list .Originally posted by BrandonMcKiernan View PostThose fender wells came out so clean. I would say go with BC racing coils just from experience. Car is off to a good start for sure.
Ja, er eit greit utgangspunktOriginally posted by superturbodiesel.com View PostSåg ut som et kurant utgangspunkt dette! Følger med
Yeah, we all bought BMWs this summerOriginally posted by xavierb View Postbmw family i see..your dads m6 is soo badass. i have a feeling youre gonna do something epic with this.
Gonna try my best on the epic part!
They turned out suprisingly nice! Thanks for the advise man!Originally posted by BrandonMcKiernan View PostThose fender wells came out so clean. I would say go with BC racing coils just from experience. Car is off to a good start for sure.
It's worth the scrub for sureOriginally posted by 12vsex View PostYea I was gonna say the same , Makes me want to go outside and scrub the hell out of my wheel wells . I'll add that to spring cleaning list .
BMW e28 528i
Instagram: Krisshansen
Thats Exactly what I want to do, Looks like its more time consuming than hard eh? Are you color matching all the wires or are you using a donor harness?
As far as that vacuum stuff... I'm pretty sure those are purge valves ? Looks strange. we here in America have them on the passenger side near the washer reservoir. Double check your lines / ports that run under the intake manifold .
Its not hard at all. I use a type of cabel from work that has 19 pairs in it, with all the wires marked with numbers. And just write down what color i solder to what number and then it no problem when I'm soldering it to the fuseboxOriginally posted by 12vsex View PostThats Exactly what I want to do, Looks like its more time consuming than hard eh? Are you color matching all the wires or are you using a donor harness?
Ok the vacuume hoses was not conected to anything so I'll probably get rid of th hole thing
BMW e28 528i
Yesterday I finished extending the cabels to the fusebox and placed it in the glovebox
Before I started today
After a couple of hours with grinding and disassembly of the brake system
Does anyone with an e28 with manual gearbox know if the clutch wire goes through the top or lower hole?
And some pictures of the new garage
Before
After
BMW e28 528i
God Damn.
What a set up. Is your garage built inside a barn??
Love the wire tuck. Want to do that to my E28 at some stage.
and i wish we got the same door trims as you do. the door pocket is soo much better than the crappy plastic one my car has
Yep its a barn or its actually a siloOriginally posted by Welfare View PostGod Damn.
Thanks I think its worth it when I'm finishedBMW e28 528i
As soon as I saw the pictures of your car inside with the RollHard sticker I knew this would be a good one, the work looks really thorough so far I'm looking forward to seeing how this build goes
