Originally posted by Queef|Chief
View Post
My Lotus Esprit S3 on Air and V8 power
Thanks, Yeah its cool to cruise in, not many on the roads so a lot of people have no idea what it is.....of even the fact that its 34 years old!My Lotus Esprit bagged project thread
http://www.stanceworks.com/forums/sh...88#post1344788
1UZ-FE V8 Slammed Scimitar build
http://www.stanceworks.com/forums/sh...72#post1480172
That might be your cooling issue. Not having a thermostat to slow the water flow can allow heated water to flow through the system too quickly for the water to drop temperature in the radiator.Originally posted by V8-ESPRITS3 View PostNo thermostat, water flow is controlled by the Davies Craig ECU.
^You would think that is figured out in the programming of the Davies Craig ECU wouldn't you?
I would think so, but I don't know how the ECU controls the cooling. If it's controlling on/off and not flow rate, then it would still have the problem of moving water too quickly.
Does the Lotus have upgraded radiator(s) or is it running the stock units?
Fitted a thicker core and bigger alloy rad, have tried all combos of thermostats, even drilled and taken the centre out nothing works!! checked for head gasket failure, checked timing, daives craig controller controls flow, it can even pulse the pump they say don't use thermostat but I tried it anyway and every thing I have tried has never fixed it? its at its best at the moment but if I get stuck in traffic for over 15mins its cooked!My Lotus Esprit bagged project thread
Thanks guys, I don't have a fan shroud so that's a next to do on the list with also a bonnet vent scoop outlet Like on the Lotus Elise, as air flow is a little restricted due to shape size of the car.My Lotus Esprit bagged project thread
Few pics found on facebook at Bristol Queens Square car meet, good selection of cars on show and the first time for me.
You missing a fan shroud would make a difference for sure
One of my next jobs on the list of things to do!Originally posted by Earl View PostYou missing a fan shroud would make a difference for sure
Esprit is now back in the Carcoon for winter, still unable to rent a local garage? all the hundreds of garages around me all full of junk being wasted makes me sick.........My Lotus Esprit bagged project thread
I always find cooling issues in custom cars really intriguing so I'm interested to see how you go on this. you've obviously done a very smart thing ducting it, not that that has any influence on your actual issue because the car cooks on idle rather than at speed. for that reason a GT40 style scoop also isn't going to help toooo much since there's no negative pressure over the front of the bonnet unless you're at speed...
shrouding the fans is an absolute no brainer, i'm surprised you built a duct for it but didn't build a shroud. if picking one I probably would choose the shroud haha.
apart from that, it looks like the front end is real, real, real packed. fluids flow due to pressure differentials and the more you cover up the back of the radiator the more you limit said differentials
and hey if it's still a no go after reviewing those things fuck it, go get the grinder and make some space for a rad with more core surface area. i'll bet you could squeeze another 80 cm^2 in there with enough hacking
Thanks,
The main reasons why I have no fan shroud is the Lotus never had one fitted? but did have the duct.The twin fans I am using are near as big as the rad so the shroud is going to be small and will not really cover much area of the rad but willing to try any thing! Its laid up now for winter so not touching it for months and need a break from it! Besides I am stuck into the Scimitar build now.......My Lotus Esprit bagged project thread
very possible going to look into trying some other fans in the near future.
