MK3 RHD Panel Van build.
  • looks like compmotives or th lines to me...if they are th lines and I have a cool secret for you if the lips are the same as were on my modern lines I had once.
    Insta Mintyhinrichs
    • Originally posted by Earl View Post
      Is the mk2 rear beam a little narrower?
      Yep I think about 10-12mm narrower. So it will pull the wheel in about 5-6mm per side. Going to see what a little bit more camber places it at before I go to the mk2 beam.
      Premiere Autosports /Instagram - Kole_Grove86
      • Test fit looks promising, can't wait to see what the wheels are!
        My Build:
        • Originally posted by philohlean View Post
          This is all speculation. But im hoping they are 3 piece bottle caps.
          Instagram : @SHMVNY_GVNG
          • Originally posted by mikey G View Post
            I sincerely hope your speculation is correct.
            My Build:
              Sadly they are not bottle caps.
              I will tell you the specs until this evening.
              Front- 16x8.5 et24 (with 2.5" lips)
              Rear- 16x9.5 et12 (with 3.5" lips)
              • Just to add to my future mk3 knowledge incase matt or chad talk me into finally getting another one, does the mk2 beam bolt right up? or is that only for a 4 lug ?
                Insta Mintyhinrichs
                • Originally posted by hinrichs View Post
                  I hope Matty and Chad both talk you into buying another one.
                  It bolts right up on a mk3, brakes and all. I just know you have to watch depending if you have abs or not. In my case I need one that has a mounting point for the proportioning valve since I'm non abs.
                  • ah okay, never messed with the rear beam before other than just putting in some of the mason tech plates to re-center the axle lol...wow what a throwback that is
                    Insta Mintyhinrichs
                    • I second they look like TH lines.
                      • Maybe some Ronals=P
                        95 318ti & 96 328is
                        Compact Build Thread
                        • Originally posted by cheaptalon View Post
                          Thirdsies
                          ig: @jonnie86
                          • I've been holding off from reading this thread for a reason , well after Reading all 5 pages .... I want another mk3 now . Kudos to doing something different ! I love it man , and the new wheels look like they are gonna be TITS.
                            Instagram - Bavarian_Steel
                            My E28 Build
                            • It's Time.
                              _DSC9207 by gtikole, on Flickr
                              _DSC9194 by gtikole, on Flickr
                              _DSC9191 by gtikole, on Flickr
                              _DSC9203 by gtikole, on Flickr
                              _DSC9211 by gtikole, on Flickr
                              _DSC9202 by gtikole, on Flickr
                              _DSC9200 by gtikole, on Flickr
                              _DSC9201 by gtikole, on Flickr
                              _DSC9210 by gtikole, on Flickr
                              _DSC9196 by gtikole, on Flickr
                              Schmidt TH-Line's
                              Fronts- 16x8.5 et24 (2.5" lips)
                              Rears- 16x9.5 et12 (3.5" lips)
                              Sorry the car is so dirty. I was going to get the car washed today but then it rained.
                              • looks awesome with the new wheels!
