in for more! oh. and Richard Ayoade is a funny man!
Project N/A 2JZ Soarer from aus
been a while and some good progress guys.
My hubcentric spacers arrived so i dropped those on the front with a set of longer studs. Finished sanding and spraying the calipers so finally put everything on. Been waiting years for this brake upgrade
Recently rebuilt 4pot jza80 rz front calipers
New slotted and drilled front rotors
2pot rz rear calipers with new rotors
new pads all around
Upgraded bigger bore 26.9mm brake master cylinder
Fluid flush and bleed
Had goodridge braided stainless lines to go on but i gave up trying to get the old lines off. Anyone else had this problem? Started stripping the nut that joins it to the hardline and felt as though the hardline itself was going to twist and crack.. Planning on getting a shop to install them a bit down the track.
Lowered the front a bit so heres how its sitting now
Car stops amazing now and pedal feel is quite solid after the bleed (after stainless lines pedal should firm up even more). Only a few cms of pedal travel before brakes engage. I will be ready to attempt some track days soon!
Decided im going to redo my exhaust before respray. Has a good note at the moment but hangs a bit low for my liking, drones a bit much, and the whole thing has become a bit ricey to me now. New exhaust will be a single right hand side exit with the other exhaust hole filled. Hopefully anyway, i have to find someone that will plastic weld it properly first.
Also will be doing all my rears bushings as they've been squeaking something horrible for the last two years and i think its finally time i did something about it.
cliffs for next mods
5zigen Mega Fireball axle-back exhaust with 2.75" stainless piping from the headers
Mount rear 97+ wing
install RCA Race rear UCA bushings
and then respray. Think im going to go with Toyotas "Black Onyx" 202 paint colour code, An oem option for the soarer.
Any feedback/suggestions appreciated!
Not sure how I feel about the shaved front inner lights, but its growing on me
Still love the car though
Originally posted by Welfare View PostGo Perth.
Rims came up awesome. What were Whitehorse like to deal with. Need to get some new lips for my RS's. And figure it would be nice to keep the money within Australia and not buy from overseas.
Originally posted by SnazzyQ View PostNot sure how I feel about the shaved front inner lights, but its growing on me
Originally posted by philohlean View PostYou're doing this so right. Proceed
Originally posted by Stancyeze View PostWhere did you get the new rings and screws?
Don't think the rings are genuine carbon fibre but im honestly still not sure
edit: the ebay ad says they are, but not sure if this is a Genuine OZ product or not
Originally posted by e34///M View PostI like this and nice Dyno numbers too. Like stock m3 s52 auto whp
more n/a power mods to come
Originally posted by 7075x4130 View PostWhy no turbo? its a jz!
I love the idea of all-motor power, instant throttle response. The induction sound of individual throttle bodies is also something i need in my life. I reckon with another 30 or so rwhp I'll reach a balance of handling and power that i can have good fun with on touge roads and on the track (even if im setting 'slow' lap times).
not bagging turbos though i think theyre awesome aswell, i just don't want one. maybe one day..Last edited by Mtt; 07-03-2014, 10:42 PM.
Just an update it two years on. Cliffs:Itb build running and tuned + a bunch of engine mods, full new exhaust. Respray done and wheels + set of Advan RGs for track use. Bucket seat and some interior work. Custom vented bonnet. Will go through chronologically - missing a lot of stuff because too much has happened (me being lazy and not posting anything)
custom itb manifold from Japan arrived and mocked up. Blacktop 4age throttles
custom made equal length long tube extractors
Parts accumulated over years. The status seat cost me an arm and a leg with currency conversion and shipping. Worth it
Headwork under construction. Cams and supporting valvetrain work + itb install. Lots of headaches
Finished and tuned. 200whp here. Sounds glorious. throttle response good but needs lightweight flywheel ( to come )
Shaving things
Servo snap the day of getting it back from paint shop
In the weeks after
A year later
Preparing for coilpack conversion - still to come.
Then I purchased a beautiful bonnet, as expected it cracked in freight. Had to repair and spray before final fitment
This pic is a few months old. Bonnet fitted. These are my 17x9.5+14 Advan RG track rims, wrapped in good rubber. Just swapped these for a set of 17x9.5 gold Advan RG2 which will be re powdercoated and fitted soon.
Final pic from the other night rocking the Futuras.
Car is still slow (as expected)but is still terrific to drive. The noise is glorious. Happy with its exterior, although a recent hills run took some paint off my front lip. Plans to come? I have some BC 272 cams, 2jzgte vvti coilpacks for coil on plug conversion, and am assembling parts for dedicated e85 fuel, and JUN lightweight flywheel. This stuff will happen at once in the next couple of months, hoping for 250whp @7700rpm.
Hope you guys enjoyed seeing the fruit of the build. I wonder if ill ever be content? Probably not
HOW did I not see this lol. This is exactly what I wanted to do with my SC! ITB's are the goal eventually but I need to get a manual trans sorted first. I also wanted to do the high beam delete but I'm planning on painting the car a different color and I think it only really works well with black like yours. Please please please post a sound clip of your car with the ITB's I'm dying to hear it. This car is just way too cool man seriously good job, might be a dumb question but are the lines you have running off of the top of the throttle bodies going to a vacuum port? Also do you guys have EGR in AUS and if so did you delete it to get away from dealing with the vacuum mess? So happy you updated this so I could see it finally. Also are those GTE valve covers? I noticed the PCV port position is different.
Originally posted by Stupid KidI need the weed in advance i can't ride my bmx across the ocean unless im high
Dear god this is awesome!! Please keep us updated on the new changes. Love the commitment to N/A and the balance of form and function. Would love to see some track footage.
