Mugello Rot M3 drift project
  • Mugello Rot M3 drift project
    So I have been wanting to build a drift/ weekend warrior for a while now and had gotten tired of only having my boring X5. So finally I was browsing craigslist one morning and found this M3. Needs a lot of work but I got it for fairly cheap and should keep my busy. Plan is to get it on the road and able to drive it to work occasionally and drive it on the weekends/ drift.
    The next day after I brought it home:
    First wash and put in some D2 coilovers, not adjusted just picked a height and put them in:
    Picked up some style 5 wheels to have a nice set of daily wheels:
    Mocked up one wheel and took off the stupid 1 piece headlights:
    At this point I decided while I have the front end mostly apart I should do some minor maintenance/ upgrades. So I ordered an aluminum radiator, a 16" electric fan, new thermostat and gaskets so keep her running cool. Also upgraded the intake with a shroud.
    Picked up a pair of Corbeau FX1 Pro fixed back seats. Had them mocked up in this picture to take some measurements and see how they look. The original vaders were complete shit so I ended up trading them for a set of LTW wheels and tires, wheels are in bad shape but perfect for sliding.
    Made my own seat mounts, came out sweet. They hug the tunnel and have about a half inch from the door panel when closed.
    Decided to strip the interior, #becauseracecar and for the fact that it smelt super bad. Ended up finding out that a couple of the floor plugs were loose and water was getting up in the foam = mold. So I am glad I did that.
    And this is where I am at for the moment, waiting on parts to come in.
    Upgrades/maintenace thus far:
    Suspension:
    -D2 Coilovers
    -Custom rear shock tower reinforcement plates
    -Racing Dynamics 27mm front sway bar
    -Racing Dynamics 22mm rear sway bar
    -X-brace
    Suspension Plans:
    -Solid mounts (engine, trans, rear subframe) I'll turn these myself
    -Welded rear diff
    -Strut tower, had an active autowerke but didn't allow for camber adjustment
    Engine:
    -Supersprint exhaust
    -K&N Intake with heat shield
    -Mechanical fan delete
    -Aluminum radiator
    -16" Electric cooling fan
    -Lower temp thermostat
    -Upgraded metal finned waterpump
    -Aftermarket/ flashed ECU
    Engine Plans:
    -General maintenance
    -Wait for it to pop and do a swap of sorts
    Exterior:
    -20% tint, may take it off not sure yet
    -Smoked tails
    -Smoked Corners
    -Euro headlights
    -Custom Front lip
    -FelonyForm overfenders
    [I]Exterior Plans:
    -Custom made rear diffuser
    -LTW wing
    -Sunroof delete (may try and make it manually tilt)
    Interior:
    -Corbeau FX1 Pro fixed back seats
    -Custom seat mounts
    -Short shifter
    -Fully gutted
    -5 panel "wink mirror"
    -Nardi
    -Autopower 6-point
    Interior Plans:
    -Make some false floors out of stainless
    -Make a handbrake mount on passenger side of tunnel
    -4-point harnesses
    Wheels:
    -Borbet Type T 17x9.5 square
    -BBS 17" style 5's with 215/40 falkens
    -LTW's with 235/40 Yokohamas May paint these white.
    -DS1's with 235/40 cheapo's
    Wheel plans:
    Re-drill hubs to 5x114.3
    Run 18x10/11 or so
    E53 4.4 Sterling Gray Metallic
    E36 M3 Mugello rot
    GEN2 TUNDRA CM
    https://instagram.com/carlmichaeljohnson/
    This looks fun..
      Some more updates, got my Aluminum radiator in the mail along with the cooling fan and mocked it up while I am replacing the thermostat, pulleys and belts.
      Had to offset the fan a little to clear
      Here is another shot of my seat brackets I made, pretty happy with them so I'm showing them off a bit
      Shot of one of my style 5's, thinking about banding the barrels to widen them
      My brother picked this Sparco seat up for $80 off craigslist, had to spend some time cleaning it and got a mean burn while doing so. Gingers...
      I'm thinking I want to either cut the roll off these tips and then hopefullly pull the tapered inside out. Or just clean it up and sell it. Opinions? Anyone want it?
      E36 M3 Mugello rot
      GEN2 TUNDRA CM
        Running good with the new radiator/ fan etc. Getting registered tomorrow hopefully
        E36 M3 Mugello rot
        GEN2 TUNDRA CM
          Here is a picture from when I got home after Staggered, going to be lifted up some and more fitted but I figured before I get it setup for drifting I may as well have a little stance fun.
          E36 M3 Mugello rot
          GEN2 TUNDRA CM
            Latest pic of the car:
            E36 M3 Mugello rot
            GEN2 TUNDRA CM
              this makes me want to get out there and finish my style 5s, your car looks great on them
