Project Dirty Dimepiece
  • Project Dirty Dimepiece
    Ok, so this is my first Datsun and second project car. This one will be a project shared with my brother in law, something we can build together as a team. This build was actually started in the Spring of last year but I had a thread on a different site. I thought it might be better to move it over here.
    I bought my 1971 510 from an older gentleman in OR in April for $5,700. It is pretty much stock with a mikuni carb'd L20B, ok interior, meh paint and NO RUST. The car ran like garbage when it arrived. Gunked up carbs, but after my brother in laws' carb cleaning it seriously ran awesome. Here are some pics of it as it the week it arrived.
    you need to post pictures.
    08 Sentra slow build
      Now the plan is to get all of my needed parts for the build prior to tearing it apart. I'm not too concerned about cosmetic stuff so ill leave the paint, spray the engine bay black and call it good. Also, the interior will be taken care of later. Gonna clean it up really nice and replace anything that is nasty or falling apart but after everything else is done. So far this is what I have:
      KA24DE
      Haltec Sprint 500
      Haltech WBC1
      Knife edge crank
      AEM MAP sensor
      Generic IAT Sens
      BC stage 3 cams
      BC valves springs and retainers
      head is ported
      90mm Wiseco's 9.0:1
      Pauter X beam rods
      Calico coated ACL Race bearings
      ARP Studs
      ARP turbo/manifold studs
      Xcessive Intake Manifold
      Cometic gasket
      240sx 5 speed
      Exedy 4 puck
      Fidanza flywheel
      LS1 coil pack setup
      05 JDM STi 3.90 clutch style R-180
      Beta stub axles
      McKinney engine and trans crossmembers
      McKinney engine mounts
      Custom downpipe and traitor pipe exhaust
      GReddy TD05H-18G w/ upgraded Kamak STS Turbine Wheel and Kamak Billet Compressor wheel
      Isis T25/28 turbo manifold
      280zx front struts
      Ermish Rear Coils 220 lb.
      T3 weld on coil kit 275 lb
      KYB AGX adjustable 95' Toyota MR2 inserts
      T3 camber plates
      T3 Steering Box Brace
      T3 Pitman / Idler arm braces
      Stainless brake lines
      280zx front brakes
      Nissan Maxima Rear disk brake conversion
      A ton of AEM Gauges and custom Speedhut speedo, tach and fuel gauges
      DGR front sump sway
      Roll cage that we will fab up to fit
      DW 1000 cc injectors
      AEM top feed fuel rail kit
      Sard fuel pressure regulator
      Dual Bosch 044 external pumps
      Generic oil cooler kit
      Byron Brackets
      Old school Recaro seats
      Mishimoto coolant overflow tank
      Synapse Radial R35V BOV
      CX Racing KA/SR-510 intercooler and radiator
      Summit braided fuel line and 6AN hose ends
      Fuel Safe SP117
      1980's Nardi Wood Steering Wheel
      Boss Hub Adapter
      Wink mirror
      Full set of T3 interior panels black powder coated
      Show and low wheels:
      SSR longchamp XR4's 14x7 +1 front w 155/55/14's and 14x7.5 -6 rear w 165/55/14's
      Go fast wheels:
      Thinking about something in 15x8 0 offset with 205/50 or 225/45 R888's
        I might have missed a few things^
          Engine bay and interior
            I'm going to have the L20B w mikuni side drafts and trans that are currently in the car for sale if anyone is interested. Mileage is unknown but it seriously runs strong and healthy. Here is a quick vid of it driving.
            Go to 10:25...
              Ok so now, I am going to flood this thread with pictures of the parts that I acquired for my list
                Block and head were machined at Mattingly Machine Shop in Bardstown, KY. They do amazing work.
                  90mm stock compression Wisecos and my dawg
                    Got this AEM EMS S2 used from a guy for durt cheep
                      Exedy and Fidanza love
                        Beta Motorsports stub axles... These are so I can use a Subaru R180 LSD and still run the stock 510 axles. These bastards are pretty expensive for what they are but worth it IMO
                          McKinney Motorsports KA to 510 engine mounts
                            McKinney Motorsports KA/510 engine cross member and trans cross member
                              nice!!!
