Airruner VIP style Build
  • #16
    Next is a tank... Im lookng at either the seamless 4gal or airlift skinny 4gal... my homie told me to go seamless but it has more 4 3/8 ports and 1 1/4, would that be an issue since my struts/compressor run 1/4 or should i just get the airlift 4gal that has 4 1/4 and 2 3/8 ports. Not sure if this matters and im just guesing (dont judge me im new to this) lol
    • #17
      You can always use 3/8" NPT to 1/4" PTC fittings to use up those 3/8" ports. V2 uses 1/4" PTC fittings, so you're going to want 1/4" air hose anyway.
      • #18
        Good to know, whats more efficient/cost effective though? How much 1/4" air hose is usually needed to do a new setup? I seen a couple 50 ft bundles on some sites
        • #19
          50' ought to do you just fine.
          • #20
            Alright.. 50 ft 1/4" air line, what about the power line is 0 gauge the way to go?
            • #21
              That depends. If you're planning on running audio gear off the same feed, then you'll need to size your wire appropriately for the total load. For a single 444c and a V2 with the wire run from under the hood to the trunk, I would run 6-gauge if you can find it, 4-gauge if you can't. 8-gauge would probably be fine, but it's on the edge.
              • #22
                Ok 6 or 4 gauge thanks
                • #23
                  Hey guys so I hit up rali for bagriders he hooked me up with everything else I needed
                  1/4" line,
                  Water Trap
                  Seamless Tank
                  and all the other accessories ill be needing.. planning on doing this install sometime within the next week or two pics coming soon!
