What do you have for shocks in the rear? Did you section the front struts?
Slow and clean E34 Build.
Originally posted by Earl View PostWhat strut inserts did you use again?I cut three inches from front strut housing and had them welded. The rears are just brand new stock struts with a-1 racing coilover sleeves, and iPD springs. I can go VERY low with this setup, threaded to the top I have 1 inch oilpan clearance. And the ride quality is perfect.Originally posted by Earl View PostWhat do you have for shocks in the rear? Did you section the front struts?"E Dirty Six, Low and Slow"
Check out my build thread
-------->http://www.stanceworks.com/forums/sh...ad.php?t=69942
I was looking into doing this a while back but never looked at pricing. It seemed like the best way to go. Are they MR2 front inserts?
No they are the vw corrado inserts.Originally posted by Earl View PostI was looking into doing this a while back but never looked at pricing. It seemed like the best way to go. Are they MR2 front inserts?"E Dirty Six, Low and Slow"
My top hats were bent when I pulled them out, so I just ordered replacement ones. Also I was using a shorter spring and wanted to compensate for the height so I opted for conical ones instead of flat. You could prob get away with it if they are in good condition otherwise I played it safe and replaced.Originally posted by BMStance View PostIs there a reason why you used the A1 Racing top hat instead of the stock? I wanna know if i can get away with using oem hardware to mount."E Dirty Six, Low and Slow"
Love the trunk, I've been thinking about doing something similar to my E30,
sigpic1991 BMW 318i (M52 Swap)
BUILD:http://www.stanceworks.com/forums/sh...ad.php?t=71013 http://www.stanceworks.com/forums/sh...ad.php?t=66246
I have something big planned so no worriesOriginally posted by Smokey Bear View PostI like when people use timber in/on their cars, keep the good updates flowing!
Thanks!Originally posted by E.Three.0 View PostLove the trunk, I've been thinking about doing something similar to my E30,
Yea man, i tossed the ideal around for awhile before actually just going in and starting.
I thinking about doing a DIY on this as well as on the coilovers i did, since either no one wants to share their secrets or no information is out there.Originally posted by SHOoff11 View PostThat trunk is awesome! Care to do a DIY? I'd like to do something like that on my e23."E Dirty Six, Low and Slow"
So today i went out to take some measurements for the Ordens because soon i will be ordering new lips and barrels. It looks like i will need a 15mm adapter in the front to clear coilovers. And also smaller inner barrels. Rears fit snug. Still debating if i should gold plate faces, or fully polish with color matched bolts.
