Easy Slider z32 missile
  • Originally posted by anti.engineered View Post
    I always wondered - why are the rose joints necessary? manifold expansion going to move the turbo that much?
    I will just say that stainless is a cruel untrustworthy bitch and loves to move around, even when you think, "that cant possibly move, its sch tubing and so thick" it will move
    Originally posted by DeltaAlpha9 View Post
    Maybe just ease of installation?
    Yes you nailed it on the head I love the flexibility of hiems
    Peace of mind maybe? lol. If I had the skill i'd fab shit for every little thing as well
    Bingo, you have to take advantage of the bits that let you get creative, keeps things fun. It takes a little time and money but anyone can do this kind of stuff its just a process
    • Nicework man, only consern is that vacuum thingy on the exhaust. work well if you have big enough exhaust and almost at the end of exhaust. friend of mine almost blew his engine with thing like that...
      Other than that keep it up, you must have alot of time and nice set of tools to pull all that off! always nice to follow when someone has time to finish pieces off like they should be
      Project car: MB 190E M50 Turbo build
      Now: MB W211 320cdi
      Ex:MB 190E M50, BMW E39 530d
      • Originally posted by Exami View Post
        Like it got a crap load if vacuum and blew something out?
        -Christian.
        • Originally posted by DER E30 View Post
          He got small amouth of back pressure on exhaust. -> pressure to engine breather -> huge pressure inside engine -> oil started coming out of wrong places.
          Now: MB W211 320cdi
            That doesn't sound too good... With the open dump out the hood the exhaust shouldn't have much back pressure
            -Christian.
              I must admit I forgot to add the photos of the one way check valves I installed to prevent said problems. Could it be possible your friend may have installed them backwards? To me that would be the only plausible way you could create a positive pressure strong enough to damage seals and gaskets.
              • Originally posted by EasySpeed*Inc View Post
                :thumbsup
                Good shit dude!
                Instagram : @SHMVNY_GVNG
                • yes.
                  FUEL INJECTED SUICIDE MACHINE
                    I can say for sure it was mounted the rightway. the issue there is, no matter what way it is installed if you buildup pressure. it will pressurize the breather. altho if you have 1way valve in it then that wont apply, tbh i almost asked that will you add one of those..
                    In case of normal breather, there is no positive pressure(only little if some) from breather meaning if there is pressure on exhaust it will move onto space where there is no pressure, in this case the breather. In your case, not sure about the piping size, just quessing that the final pipesize is about 4" and the wastegate pipe 2"? and exhaust 3.5"? meaning that even with the 2" wastegate pipe inside the 4" exhaust the area of flow is pretty much the same as 3.5" so it wont have constrict.
                    4"=12,56"^2 area of flow..
                    3,5"=9,62"^2
                    2"=3,14"^2
                    Now: MB W211 320cdi
                    • Every custom build has to have a few Ls components
                      I have decided to go with Ls 585 coils since I am going stand alone it should be a nice reliable addition
                      The only problem with them is how awkwardly shaped they are
                      Few test placements to see how I want to position them
                      They fill the valve cover humps decently l think
                      Keeping it simple and utilizing the factory cage, but chucking the the main frame
                      The cage is literally being welded to a more simplified brace
                      Like this
                      A few lugs welded onto the valve covers and a stainless 1/4" bar molded to the Ls coil cage
                      Starting to look gnarly
                      • Damn I wish I could fabricate as well as you man. This car is totally spectacular. Also is that an m5 in the background in the first picture?
                        • Something cool is brewing (VIDEO CONTENT )
                          I will first start out with saying that this is more of an aesthetic update since we will be making this bell mouth out of a non conventional material
                          The machine before you is a glass lathe and if coupled with large portions of your life can create some interesting things, especially if you have been doing it for as long as the man that made this for me
                          I had to use my phone for most shots so they are not the best, but in my defense I needed to help with holding torches/tools and try not to get in the way
                          Outer body of the bell mouth being established
                          First cut
                          Finished outer
                          Removing excess material
                          Preheating
                          Internal portion of the bell being finessed, they use graphite tooling as to not scratch or stick
                          More finessing
                          Just like in welding helmets you need to wear shaded glasses at all times so I placed the shades over my camera to see the effect
                          Measure twice as they say
                          Cut then flared
                          Skipped a few steps (I had to hold many, many things) but here it is after the inner and outer pieces were conjoined
                          I know the glass intake/bell mouth has been done before but I was never impressed by any of them. They basically take a glass tube and flare the end, pretty boring. But now going through this process I understand why. Its ridiculously difficult on all fronts, from the knowledge required to the massive expense of the equipment needed
                          Its a beautiful thing when an idea comes to fruition
                          You might be wondering why its two pieces and the simple answer is you cant really do inverted flares with glass. It would create a lot of stress and more than likely thin out so much so that the glass would become unstable
                          Also just so we are clear none of the actual glass/lathe work is my doing, I would need decades of pure glass experience on an industrial level to do this, it was just an idea I had and was lucky enough to know peeps that did
                          Any who back to my boring section of the build
                          As you can see it is complete now and back in my shop!
                          Basically we kept the mounting simple, just a little flare wrapped in a rubber isolation gasket to keep the glass from touching the turbo
                          Amazed at how precise this thing is
                          Now its the turbos turn
                          Had to cut her down a bit
                          So I could fit it on the lathes 12in throw
                          And yes this was as terrifying as one could imagine spinning a turbo housing at 500 rpm, but that ridge had to be machined for better fit dammit!
                          V band
                          Machine everything
                          Worth the trouble for that fit
                          Preheat then weld time
                          I don't mean to toot my own horn but I think this tops the Gnar charts
                          Hopefully this tickles your fancy because it was a stupid amount of work, Oh ya since I love this forum and everyone here so much I also have a video on Youtube that I would definitely suggest watching
                          Here is the link
                          https://www.youtube.com/watch?v=AcY9OH4Asgw
                          • This build keeps getting better and crazier
                            87 RX7 5.0 (driftcar)
                            • oh my actual fucks.
                              this is absolutely incredible!
                              DRIFT BUILD
                              • I cant even put into words how impressed I am by that... Missile my ass
