I apologize if this was stated earlier on... but, what color are you painting the bay?
I have no idea what I'm doing...
I'm glad someone else has some rusty holes in their shock towers to repair so I know what I'm doing when I fix mine haha. Good luck on the bay shave!BMW E34 V8 - Daily
Merc 190E - Sold
BMW 635CSi - Project
Mercedes 190e Build Thread
Euro BMW E24 Build Thread /Style is personal, fun is universal._____IG: @levonvandamage
Thanks guys, the holes in the bay aren't really rusty. Also the bay color I'm not sure on. Most likely it'll be the car color or a cream color. The only way it'll be a different color than the body is if I end up wrapping the car for sowo.I’ve had too many cars to list and most of them sucked.
running a bead and cutting it will remove the possibility of flex, which is exactly what you want if you're shaving and painting it. Stitching it will suffice, but it could flex and crack after awhile.
Indeed ever coat is the brand and it's far superior in comparison to other bondos I have used. It spreads evenly, very strong, and easy to sand. Here is a link to the good stuff (I'm sure you can find it cheaper, but this is the local place i use)
In addition, I would go over your windows with a razor blade and take all the metal shavings off right now and mask the rest of your car off (body and windows). You will quickly have rust spots sinking into the clear coat and stuck in the window seals. No fun trust me!
Looking good though!
I appreciate all the help man, I'll order some of that filler when I get to that point. I'm doing all the body work and painting the whole car too, so will it matter if I get metal shavings on it if I'm gonna sand the whole thing down anyways?Originally posted by Heist View Postrunning a bead and cutting it will remove the possibility of flex, which is exactly what you want if you're shaving and painting it. Stitching it will suffice, but it could flex and crack after awhile.
Looking good though!I’ve had too many cars to list and most of them sucked.
np and I would just try to keep the shavings off the paint and glass if possible. Just tape around the bay and cover the rest in cheap home depot painters plastic. Saves you work in the long run and lowers the chance of it embedding into the new paint.
Just think of all the tiny shavings flying around at high temps landing on pitted glass and paint. They dig into the paint and when you sand it it's going to put it further into the primer/paint.
makes perfect sense. ill definitely go grab some plastic sheeting and cover up the paintOriginally posted by Heist View Postnp and I would just try to keep the shavings off the paint and glass if possible. Just tape around the bay and cover the rest in cheap home depot painters plastic. Saves you work in the long run and lowers the chance of it embedding into the new paint.
Just think of all the tiny shavings flying around at high temps landing on pitted glass and paint. They dig into the paint and when you sand it it's going to put it further into the primer/paint.I’ve had too many cars to list and most of them sucked.
I definitely wouldn't run solid beads. I do agree, however, about fully welding it. Run some heavy tacks, say 15 at a time, spread out and allow them to cool. If you run beads over that sheet metal it's going to warp and you're going to **** your life because your nice flat piece of sheet metal is all fucked. General rule of thumb is if you can hold the back of your hand against the weld it is cool enough to start welding again.
Keep it up, dude. I love me a shaved bay.
Originally posted by KielanWell dip me in shit and roll me in breadcrumbs...
Good point ^! I probably should have mentioned taking it in sections to keep it from warping is highly recommended. In addition, you don't need thick beads just flat lined runs. The goal is to get enough penetration, but keep the wire down so you don't have to grind for a week.
Another useful thing is using flat copper on one side if you're filling holes or whatever. The copper will not weld with the mig and it will allow you to fill gaps and created flat edges.
