Originally posted by doktor_b
View Post
I have no idea what I'm doing...
Something just happened in my pantsOriginally posted by Offczarkowski View PostHow about m20 like this one:
Fully rebuilt + ITB + stroker ~2.9IG:uvebeenrobd
Just ordered this from AKG:
rear subframe toe/camber correction kit. This sunday me and a friend are planning to finish the fab work in the bay, then hopefully i can get the bodywork done in another week, then all my money is being saved to buy a full euro plaid interior.
useful updates soon.
list of things i need is too longI’ve had too many cars to list and most of them sucked.
Canibeat just posted my feature
heres a few pictures from it:
Full feature is here:
http://www.canibeat.com/2013/12/love...gging-bmw-e30/I’ve had too many cars to list and most of them sucked.
I did some things. I'll just let the pictures speak for themselves, Please excuse my somewhat awful welds, theyll be covered after body work.
Before/After Pictures:
I also have a question for anyone who's shaved a bay before and can help me out:
What should i use over the welds? I'm not sure if i should use a thin bead of seam sealer before i bondo the corners or i had a friend suggest using duraglass. I'm still a couple weeks away from that step but i need to know what route to go once i get there.
My friend brought his camera over and took some cool shots so ill post those later
Any specific reason you're stitch welding it? I would run a clean bead around all of it and use a grinding wheel to flatten the welds. Finish it off with some roloc pads to flatten the weld out. Once the weld is cut down buy ever coat bondo (not the cheap shit) and run a bead over it with your finger. After that sand your fingers off (sponge pads help near the end).
It's better to weld the seam shut now and save you from the misery of cracks. The other option is using paintable flexible seam sealer and going that route, but it will never look as good. Considering the time you have put in already, go with option one imho.
only reason i stitch welded was because i wasnt sure what to do haha. i didnt know if i should do a full bead or if the spot welds would be better then use seam sealer. but since you suggest it ill definitely run a bead along the whole thing, thanks for the help man.Originally posted by Heist View PostAny specific reason you're stitch welding it? I would run a clean bead around all of it and use a grinding wheel to flatten the welds. Finish it off with some roloc pads to flatten the weld out. Once the weld is cut down buy ever coat bondo (not the cheap shit) and run a bead over it with your finger. After that sand your fingers off (sponge pads help near the end).
It's better to weld the seam shut now and save you from the misery of cracks. The other option is using paintable flexible seam sealer and going that route, but it will never look as good. Considering the time you have put in already, go with option one imho.I’ve had too many cars to list and most of them sucked.
