I have no idea what I'm doing...
  • here's the pictures:
    I’ve had too many cars to list and most of them sucked.
    • im so jealous of your car, its going to be wicked!
      • I just want you to know that this still my favorite e30 ever as long as you finish it. It's turning out amazing. I bet you make your mommy proud. Maybe.
        IG: ashtonlafleur
        • Originally posted by MrViicc View Post
          thanks man!
          <3
          • I got a lot done today. Well, a decent amount.
            No pictures but i mounted the e34 pan and oil pickup,
            Decided to give up on stripping the valve cover myself and gave it to a friend to sand blast. that thing is a bitch
            and then i ate at sheetz and drank coffee
            and then i welded in my new frame rail pieces, this time using 16 gauge, its 1000x sturdier
            now i cant sleep because i drank coffee at 1:30 am
            pics:
            the edges hadn't been ground in those pictures, dont worry, not that you would worry anyways.
            • Awesome build man, been following it for awhile. Can't wait to see the interior in the car!
              Instagram: @mattragsdale
              '97 M3 build
              • That's looking really good dude.
                IG: ashtonlafleur
                • I've been slacking horribly on taking pictures of what I've been doing, so instead, you can read what I did.
                  Bought more stuff, more than I could technically afford at the moment.
                  I got:
                  New (used) rear axles
                  80°c thermostat
                  aluminum thermostat housing
                  Rear subframe bushings
                  Serpentine belt
                  Injector o-rings
                  Used rear hubs are on their way
                  I put most of that stuff on, still cleaning up the diff and I'm gonna paint it so the rear end isn't together yet, but I did clean up the rust on the subframes and trailing arms and painted all of them.
                  My parts list is getting shorter since I just ordered the last sensor I need for the swap, but the remaining parts are big ones like euro bumpers and front lips.
                  No word yet on when the coilovers will ship, BC is building them now.
                  • Metal work in the bay is 99% done, I'm pumped to be done with that. Welding is all finished I just have to go pick up a small angle grinder to get into the last couple difficult areas.
                    here's the "stance" update
                    this is what I'm going for, with slightly less camber. i don't have any suspension in right now so I just had the wheel held up there. the quarters will be pulled out flat since with the hub actually mounted it will sit much farther out.
                    • Such a nice work on that bay...ull be able to stand in there.
                      wooow them big lips
                      IG@valentinoduplan
                      • Originally posted by Tino21 View Post
                        wooow them big lips
                        Thanks man. The most work is yet to come with the filler unfortunately haha
                        • Coming along great man. Enjoyed seeing this down at H2Oi this year.
                          Instagram: "Cole_Lenhart" Out of Thread Builds Shoots and Progress
                          Just a Truck Build: "Here"
                          • Really impressed with the work you're putting in! Coming along great!
                            • is this to run the harness through the rails?
                              R.I.P P.WALKER 2013/11/30
                              • not impressed by any of this. it all sucks. would rather see an aveo on 15x10's
