Finally she runs again! That was only the longest clutch job in history. No pictures, but here's the point form of the issues we encountered:
-Input shaft was seized in place. Conventional removal techniques were replaced with ingenuity. Cost an extra 2 hours.
-While removing input shaft, dropped a bit inside the primary drive case. Fetching this required opening up the case, 8 hours extra work.
-As so did not have the proper tool to keep the pressure plate depressed, and the fact that the slave was dead, this process took extra time to make everything work.
-After removing the clutch assembly, we had to mount the new assembly. 4 hours were required to prepare the new assembly and figure out how to insert the clutch plate, pressure plate, and slave all at once.
-Getting the slave to fit into place required 2 hours of hammering on the pressure plate, slave, rotating the flywheel, and actually hitting the edge of the clutch plate itself.
-Due to lack of clearance, we couldn't get the pressure plate onto the dowel pins. Ground them shorter and used steel plates to shim everything so that the pressure plate could be rotated into place.
Those were the major problems, not to mention the time I backed a ratchet against part of the frame of the car and could barely access the switch on it. So many little things like this that just didn't work. That's the downside to not having your own place to work!
As the snow clears, expect some pictures! I've got some ideas in the works for getting her a little more to my taste.
