Originally posted by Quillhill36
View Post
Slammed Jeep Patriot
Lmao, awesome stuff going on here.2 328i e36's
Saabaru linear 2.5na
Various projects.
Intro;
http://www.stanceworks.com/forums/sh...19#post1598619
Shit photo to show the difference between standard height and how mine sits.
Still want to get the back 5-7mm lower to sit the same as the front. Have hit up BC coilover manufacturer to see if i can swap out the shock to one that will suit my setup better.
Fabricator/welder mate said he could do a better job welding the control arm than i did (no surprise) so i will be getting another batch laser cut and he may even tig them up for us.
Ive got 10mm spacers on the back of mine and it helps fill out the gaurds alot on my car.
Unfortunately the dodge doesn't have any support for Toe adjustment (outside of factory arms) altho the factory does have quiet abit of adjustment.
Find a good suspension shop, you can have your dampers shortened if there is no smaller factory optionOriginally posted by willis6057 View Postcheers, might still put 5mm spacers on the rear.
have ordered EVO X adjustable Toe bars for the rear too.
BC got back to me, they only offer a 10mm smaller damper..... which sucks
FB: @DumbassCarCrew - IG: @fruttolo_dumbasscrew
had some spare copper pipe & moisture traps= new dump line & two more moisture traps between the compressors and tank. Same goes with plumbing in a air line connection to pump up tyres and what not.
have been looking at changing the rear strut mounts to a adjustable one that mounts sideways on the damper instead of directly below the strut, which means i should be able to order longer dampers, to get more lift and just thread them down more to accommodate for the extra height
