Slammed Jeep Patriot
Bit of an update:
- Removed all the green.
- Started doing some work to the engine bay.
- NEW WHEELS! there Work Gnesis GS1, sit flush front and rear with no spacers (sorry for the crap phone pic) cars sitting a bit high in the photo because i only just put the rims on and jacked it down and drove 10sec down the road
How do I change the title of a thread?
started with stock 2011 rear bumper (lower half)
trimmed it a bit to see if it would even work sitting 100mm lower than stock bumper
grafted diffuser
closed exhaust outlet and smoothed the other side to match.
test fitted
decided best way to finish the ends would be to graft the bumper to s set of standard style mud guards
started trimming/shaping them to suit the bumpers body lines
cutting, plastic welding, fiber glassing (the inside) and some sanding
laid some primer down
put the bumper build on hold for a bit and decided to pull my finger out and finally install bags
some parts started arriving
built two compressor mounts for under my car
Decided i wanted to run digital pressure gauges
bought a another dash surround
some junk gauge holder, trimmed to suit the dash and mounted.
infill panels
few layers of fiberglass
sanded after drying
mounted the tank
painted
wet sanded/polished/waxed
applied a ceramic coating
started running the airlines
stainless braided/copper lines
still want to run a full size spare; ive needed 3 times this year already
not the neatest hard lines, but you wont even see them so i'm not fussed
using one of these controllers, so go a mate to make us a 2m long cable extension
still need to plumb in the moisture traps; have allowed room/straight runs in pipe to install them.
