Just another E30 build.... (a.k.a. The Bronzit B*tch)
  • Nice work man! You can get the rear wayyyy lower if you want. Mine looked the same as yours when I first did my bags but when I rolled the rear fender it actually pushed the fender out some and I got a lot better fitment. Also, on the front, if you want that to go lower just trim the pinch seem in the fender well.
    Instagram: @dillonmakar
    1986 Bagged s50 BMW e30 HERE
    • Just needs a rear valence =)
      95 318ti & 96 328is
      Compact Build Thread
      • Originally posted by eastcoastrice View Post
        how did you do the bumper tuck in the front?
        Drilled out the cylinders on each side, then compressed each side. You could take the shocks off and compress them in a vice, but i just kicked them and they went.
        For the rears im swapping the 25mm adapters to 20mm to pull them in a bit, and them roll them which should be perfect. In the front my oil pan is whats stopping me. its sitting on the ground holding me up, what did you do for your s50?
        I know!
        PSA: LOOKING FOR ZENDER REAR APRON!
        Instagram: @GregKline55
        1999 M Coupe
        1987 325e
        1987 325IS
        • Started to work on my trunk, took the old carpet out and replaced it with wood. Fit perfectly the first time so that was nice! Tank bolts to that and the air lines come up from a hole behind the tank.
          IMG_20150215_143633
          IMG_20150215_143645
          The wood will be getting carpeted, went to Home Depot and picked up some of the closest stuff i can find. Its a little lighter in color but itll do.
          IMG_20150215_150612
          Thats all for now
          1999 M Coupe
          1987 325e
          1987 325IS
          • Got some photos from ian (eethirty), he posted them on his thread too, my brakes are almost done! Theyre being finished as I write this!
            Untitled
            Untitled
            Untitled
            Untitled
            Untitled
            Untitled
            Final results in a few days!
            1999 M Coupe
            1987 325e
            1987 325IS
            • Originally posted by K-Line View Post
              IMG_0795
              Passed this pic and did a double take! Looks like a helluva spoiler!
              -Christian.
              • Looks great! always loved the is "cow catcher valance". Probably wont use the one i bought though
                ______________
                • Originally posted by DER E30 View Post
                  Yeah the classic western plow wing mod lol
                  I love them too! But ive been thinking about running euro bumpers and finding an Mtech1 or alpina front valance.
                  1999 M Coupe
                  1987 325e
                  1987 325IS
                    I know!
                    Yeah, that should work for the rear, plenty of of room back there. As for the front, just put some washers on your motor mounts. Don't get crazy because you will get some weird angles but it will definitely help. I'm sitting on my oil pan still after raising it up and I still need to get it about 1/2" lower for the fitment i want.
                    • Would running subframe risers without the diff spacers fix the driveline angle with washers on the engine mounts?
                      95 318ti & 96 328is
                      • Originally posted by dillon7 View Post
                        How thick in total do you think your washers are? This was the plan for now, my buddies gonna make me some custom taller motor mounts eventually.
                        I think you would run into the issue of the diff input plange/universal joint hitting the upper part of the subframe where it runs through, im not positive though
                        1999 M Coupe
                        1987 325e
                        1987 325IS
                        • Nothing a BFH couldn't fix right? =)
                          95 318ti & 96 328is
                          • Originally posted by Earl View Post
                            That's true lol but I'd have to raise the trans too which could hit the tunnel, idk I'll have too look into it
                            1999 M Coupe
                            1987 325e
                            1987 325IS
                            • Just wanna keep u guys updated. Greg recently did the Greggor-Not-So-Smiley headlight upgrade. Greg asked me to show you guys.
                              Untitled by e30ian, on Flickr
                              He also recently visited the Nurburgring,
                              And the BMW museum!
                              Cheers!
                              Instagram: ian_ballzz
                              e30 build thread
                              • Originally posted by eethirty View Post
                                And the BMW museum!
                                What's up with that intake mani? CNC aluminum or CF???
                                -Christian.
