1966 Volvo 122
This topic is closed.
Not sure what you mean by 'nearest to the engine? The upper A-arm? There is not much meat to cut or is there?Originally posted by Keith602Needed to cut the upper arm nearest to the engine for the bag to clear (after the above pic was taken).
This guy recreated the upper A-arm for a coilover conversion, but only because he cut and widend the shock tower in the front suspension;
I guess removing the cup all together like they do for a coilover conversion could be an option, right?Originally posted by Keith602Needed to cut the spring cups in the back quite a bit as well.
You're leaving it like this? Car insurance company would have my ass over here if I had an accident without one. How about this; http://www.volvoforums.org.uk/showpo...&postcount=184Originally posted by Keith602We'll see. Pulled the sway bar obviously.
Never used bags so a noob question; what about diameter? When I'll be shopping for bags do I get bags that aren't wider in diameter than my springs when deflated, correct?Originally posted by Keith602I went with the 2400lb bags, which are still a little too big...
Sorry for the truckload of questions. If I get there I will be needing to import the parts from the States, better make sure I do it right the first time
Cheers
I didnt cut that, but yes, that could be cut if you wanted to go lower. The area I was referring to was actually below the spring cup where it rubbed, couldnt think of a way to describe that.Originally posted by Bartezz View PostAh crap, now I know what you mean. You cut this off, right?
Thanx a million on the detailed info and pics. It's helping me a ton!
Did you check the link on the sway bar? (http://www.volvoforums.org.uk/showpo...&postcount=184)
Cheers,
Bart
Glad I could help. Any pics of what you have going?Originally posted by Bartezz View PostThanx a million on the detailed info and pics. It's helping me a ton!
Cheers,
Bart
Nothing going yetOriginally posted by Keith602 View PostGlad I could help. Any pics of what you have going?
First things on the list is to replace my engine which is almost done. Specs are very similar to http://www.vclassics.com/mppe1.html but with a different cam and possibly with megajolt ignition.
Then my plan is to swap the M41 gearbox with a T5 and the rear axle with a 240 axle so I have disc brakes. But since I haven't got much experience working on cars this all is long term planning. Learning as I go.
When this is all done I'm hoping to bag the beast
Cheers,
Bart
Cheers,
Bart
Sounds like a good project! Start a build thread if you haven't yet
It rides much better!. It was basically as low as it could go on cut springs, so having some suspension travel is great. I dont wince and brace myself over little things in the road anymore haha.Originally posted by The Simps View PostVery much enjoyed going through this build start to finish. Very cool car dude and nice, tasteful mods!
How does it drive for comfort on the bags compared to the cut springs you ran previously?
