adapted the new throttle. fires right up and idles. very responsive throttle. missing the TB to TB adapter gasket still but seem to be holding a good seal.
I whipped a solidworks design. exported to a .stl then to a .gcode via a "slicing" softwares...then loaded it into the printing app....click print.
Also insulates the throttle body from the intake manifold and barely even heat soaks. I am planning on a carbon intake spacer to drop the heat soak down a bit more too.
Nice progress.
I heard that those LED H4/H7 replacements do not even come close to regular Halogen bulbs light-emitting wise.
Could you tell if this is true?
catch can works great. had the front wheels balanced and replaced the front ball joints. highway is smooth cruising.....onto adding back the drivers window
