Project CQ
  • #46
    been anther productive day.
    IG: awscarguy
    '90 Jetta - TSI swapping
    '13.5 Jetta GLI - new daily toy
    Haus of Dub
    • #47
      Dropped off the alternator to get rebuilt....called me back 3 hrs later and said it was ready. wow
      time to tackle the head
      I need to buy or borrow a valve removal tool.
      IG: awscarguy
      Haus of Dub
      • #48
        3/8 drive 17mm deep socket on a small extension with a hammer. It works great on the 1.8t's
        • #49
          add a magnet.....how about the install?
          Issam over at INA Engineering hooked me up with a set of new OEM valves shipped for my wholesale cost of non oem valves.
          IG: awscarguy
          Haus of Dub
          • #50
            pulled each wrist pin and lubed everything. new rings and rod bearings. new crank bolt, new main bolts, new metal water pump, front/rear main seals, magnetic drain plug, and new intermediate shaft seal.
            IG: awscarguy
            Haus of Dub
            • #51
              found a radiator solution
              still waiting on valves
              started to modify the power steering system back to a vac assit
              IG: awscarguy
              Haus of Dub
              • #52
                picked up a 2004 A4 k03s. little bit of a scrubbing and paint...
                also going to swap on a obd2 vr6 12v throttle body...so i needed an adpater. ill print this out in a day or so.
                IG: awscarguy
                Haus of Dub
                • #53
                  even though i am a chip tuner for a well known Canadian shop..started to "bench" flash a few ecu's into 557p's with my own tools so i can start doing my own tune for this project.
                  IG: awscarguy
                  Haus of Dub
                  • #54
                    ordered a smaller diameter TDI water pump pulley to increase the water flow.
                    ended up picking up 2 AEB heads
                    had to modify the pilot bearing since i started with an automatic crank from a B5
                    IG: awscarguy
                    Haus of Dub
                    • #55
                      IG: awscarguy
                      Haus of Dub
                      • #56
                        radiator is in. need to weld a bung in for the fan switch.
                        IG: awscarguy
                        Haus of Dub
                        • #57
                          I can't wait to see this finished, it looks like an awesome swap.
                          The hillbilly equivalent of a nasa substation worker.
                          Originally posted by Dubway5887
                          I felt bad for that dude. Of all places for a sink to be at a car show... Maybe sink holes like car shows like tornado's like trailer parks?
                          • #58
                            ^^ thanks man. Not many have done the swap. I am on the only one dead set on having a side mounted radiator.
                            2nd to last MK3 TDI water pump pulley left in VW USA stock. Should push more volume. Also have a MK2 thermostat water outlet on order.
                            IG: awscarguy
                            Haus of Dub
                            • #59
                              off to the garage!
                              IG: awscarguy
                              Haus of Dub
                              • #60
                                needed to tie in a few coolant lines so i picked these up. looks like these are made for sensors...these have a 3/8 fitting so i can put a 90* and a 5/8 barb fittings on.
                                also snagged a new 2300 cfm Perma-cool fan. it is nice having Summit Racing 20min away
                                IG: awscarguy
                                Haus of Dub
