i dislike you now.... you have a g, fc, and a 13 and im twittling my thumbs with my one car.... i gotta get on my a game haha but not a bad deal for that car fuck i paid 2k less for my car and it has WAY less mods! but keep it up man! cant wait to see the progress!
Blake Olsen's s13 Coupe Drift Build *Not as cool as my FC, but also with a v8* !
SILVIA BUILD! ==>http://www.stanceworks.com/forums/sh...ad.php?t=44686
Intagram: @DaHawaiiKid_ClassicAura
Originally posted by RolledAndPulledG View Post
UGHHHH those are my two avorite cars in the world. I just started following Ray on instagram and had no idea that this used to be his car! I'm stoked to see what you make of the S13 and if you are ever in Nor Cal again hit me up! I'd be down to get some bomb food with ya haha.
Thanks!Originally posted by crazylegs View Posti couldnt imagine having to go back through and fix someone elses mistakes, im having enough problems getting mine in the first place.
Keep up the amazing work beautiful cars man
Haha its crazy in person... Legit BN touching the groundOriginally posted by scweet14 View Postdamn that 240...
Yeah, haha crazyOriginally posted by Staggered View PostGahhh this thing will be great when you finish it, and that 13 is unbelievable
Yeah same, Next event is on the 9th here...trying to male thatOriginally posted by LaMaR- View PostIll make a build thread after the next drift event, I have a ton of work to accomplish in the next 2 weeks if I plan to drive... Cant wait to see you update this and the FC thread of course...
Hahaha hopefullyOriginally posted by aeok18109 View PostThat PO needs to get his s ced out with the business end of runaway trans jack -_-. I'm sure you will convert this cosmic turd into a masterpiece.
He'll yeah!!Originally posted by PrimeLuxeZ View PostDamn dude, it has its pros and cons, I'm in for the epicness. Just another build to be excited on.
Haha, I mean, it sucks there's sobmany problems, but they're honestly small when looking at the big picture. It feels really solid when drivingOriginally posted by DaHawaiiKid View Posti dislike you now.... you have a g, fc, and a 13 and im twittling my thumbs with my one car.... i gotta get on my a game haha but not a bad deal for that car fuck i paid 2k less for my car and it has WAY less mods! but keep it up man! cant wait to see the progress!
Hahah yeah shits crazy! I'm not upper there much anymore but if I am forsureOriginally posted by Chunter View PostUGHHHH those are my two avorite cars in the world. I just started following Ray on instagram and had no idea that this used to be his car! I'm stoked to see what you make of the S13 and if you are ever in Nor Cal again hit me up! I'd be down to get some bomb food with ya haha.
Yesterday, got the rear alignment out of the way. Took awhile like everything else with this car has but its all good now. Toe and camber are exactly zero. I also strung the car and made sure that was good too lol
Pictures dont say much but here it is..
Then i got under the car and fixed the fuel line, in all honesty i should have done this first lol, but better late than never...plenty of clearance, the cooler fuel temps should help performance too, fingers crossed lol
While i was working on the rear suspension i decided to fest fit the front wheels from the fc3s..the specs are 17x9.5 -19, which happens to turn out being the same outer measurement as a 11j +0. I like the amount of poke. Once i get wheels on the car (I plan on ordering another set of Centerline REV's to match the FC, but 18x11 +0 so i have room to run a 25mm 5x120 adapter and use them for spares on the FC) I will get 50mm origin overs and see how i like them on the car, may get longer studs and throw a 1/2" spacer on each side. Fronts i will do the same as the fc, or maybe a 18x9.5 -12 so i can safely slide on a 225/35 without fear of debeading with low pressures for grip. Onto the pics!:
this is without weight on it obviously, barely fit under the arch..
Looks good, but with a 235/40 on an 11, the car could definitely stand to use a spacer. I want this to be bubbly just like the fc, just not as extreme
Then i started messing with the hydraulic ebrake on the car, its all plumbed in but not bled. You can also see the good wiring job on the switch panel!
After this I went and saw the hangover 3 and grabbed frozen yogurt with this beaut...
More to come..
Please give this man a statue. I'm sub'd. Again.Lucas
Camber can be easily measured with a plumb bob and a protractor. It takes practice, but can be pretty accurately done. Toe is a bit trickier. I've never been able do it off a rack. But I have a buddy who uses string to line everything up. Kid managed to get 0 degrees toe (plus or minus .05 degrees all around) without an alignment rack. (to check his work, I took the car to my schools shop)Originally posted by dvsmethodz View PostYou do your own alignments? I need your skills.
Making me want to get back to work on my LS Swapped S13. Also dont know why he swapped LS1 heads on a 5.3/6L The truck heads flow retardedly good.Originally posted by Jesus Christhe mustve enjoyed that bj.
