Originally posted by detsooB
View Post
91 Nissan Hardbody
Only problem I for see with leaf and bag setup is you will only go as low as your leaf hangers, Cant remember if you did a redrill. Do a notch and new hangers and I think it will work out. Im just going the 4 link coil route for spirited driving hahaWhen in doubt, cut it out...
I have the redrill done and hopefully a notch coming in the spring (I finally got a mig welder!!) I think what I'd do is mono leaf the rear so it would be slammed. I heard you can actually break the leaf springs from flexing so much. Nothing wrong with some "spirited" driving lol I'd do coils but I want it to be real low. I don't think I could go that much lower static the way my exhaust and frame is now.Originally posted by TheCrabMaster View PostOnly problem I for see with leaf and bag setup is you will only go as low as your leaf hangers, Cant remember if you did a redrill. Do a notch and new hangers and I think it will work out. Im just going the 4 link coil route for spirited driving haha
yeah mono leaf is super floppy, so basically leaf spring/bag setup is like having blocks that change sizes haha. But anything is possible, im gonna probably end up doing a custom header so my down pipe can tuck above the frame because stock hangs lower. But only thing is once you go so low you basically have to stop your exhaust before the axle or else you have to go up and around it. I want to be a healthy 2" from the ground with the frame and front cross member.Originally posted by detsooB View PostI have the redrill done and hopefully a notch coming in the spring (I finally got a mig welder!!) I think what I'd do is mono leaf the rear so it would be slammed. I heard you can actually break the leaf springs from flexing so much. Nothing wrong with some "spirited" driving lol I'd do coils but I want it to be real low. I don't think I could go that much lower static the way my exhaust and frame is now.When in doubt, cut it out...
