type a's were better
The Memory Red Golf Build.
Lower the rear more & cleaned her up for Euro Hanger tomorrow.
Small update...
Finally have a daily so I have not been driving her a lot at all. Basically just get her out on weekends. which is good because with the new height and the modern lines have been making the subframe get well...
a bit beat up.
Red will basically be sitting for the next few months waiting for H2O. I have a bit of work to before I leave, just normal things like oil change, trans fluid change, coolant flush, fuel filter, brake fluid flush, brake pads, replace that crushed oil pan & get the car cut & buffed.
later guys.
Well I have parts coming & to finish before H2Oi to give Red a little face lift change. Also went out tonight & snapped a new set of Red as well...
Oh it's a big list still. Here is a idea..Originally posted by Raarasutra View PostGorgeous MK3! Love what you've done! What's next?!
Body- euro golf front & rear bumpers, CL lip, euro hatch, abt textured rep skirts, euro rad support & hella all red tails. I have a Early Vento grill on its way as well as a set of Kamei Bumper ducts.
Engine- TT 298 cam, TT big valve kit, port & polish head, LSD, TDI 5th gear, replace all seals, gaskets and new rings and bearings
Suspension & Brakes- Banchwerks drop plates, 1" ball joint extenders, Tie-rod flip, G60 or VR Cailpers & 11" rotors.
Also going to doing the wire tuck this winter and work on the bay as well.Last edited by GTIKole.; 09-15-2013, 11:52 AM.
Thanks man! I always loved the look of mirror deletes on mk3's and my buddy gave me the block offs at Vag Fair so I was stoked hahaOriginally posted by DaCabrioGuy View PostI just noticed that you did a mirror delete. Little things like that just make it pop. Well done!
Not to be taken in the wrong way but how was the motor raised 1.5"? The reason I ask is 1" raise barely fits under the hood. Also I raised my aba 3/4" and it appears the same as your picture in the garage with the hood open.
edit: My pan now sits well above the subframe and cannot be touched or seen.Last edited by bmwfan597; 09-15-2013, 04:24 PM.
As far as I know the PO said it was raised 1.5". The pan is above the subframe, only reason the pan has a dent in it is from a terrible bum I hit on the way home from SOWO.
I also flipped the throttle body to gain some clearance.
When the motor comes out I'm replacing the mounts with BFI mounts and getting euro image spacers.
