Stance noob GTO build
  • Figured out why I was losing air pressure causing the one tire to debead. The billet valvestems I put were tight enough on 3 wheels... And not tight enough on the 4th wheel So I tightened it so hopefully I can get my tire back on the bead this evening so I can get all 4 wheels on
    Follow me on instagram: @watsupitsdenny
    check out my bagged GTO build
    • ^This, this is what happens when u give a monkey a wrench. Smh
      "how do you drive that? Does it have those lifter shocks on it like the low riders?"
      -Faithful Autozone Customer
      Make me insta famous @isupa_shaun
      • Originally posted by Shaun708 View Post
        Fite meh!!!!!!
        • So thought my debeading issue would be quickly solved, I thought the tire with a torn bead was on another wheel (which is holding pressure at 40psi on the nose) but it looks like that is not the case... Or this has another tear or just didn't bead right. So we're going to throw some bead sealer on it and cross our fingers. Otherwise I'll spend $80 on another falken... So that isn't absolutely awful. And my picture with bubbles won't upload...
          • I love this way too much, thank you.
            IG: @sebastienaudeon
            1974 Porsche 911S
            Originally posted by TRaNz
            *pats Sebs head*
            there there.
            keep calm, go mash your face on a car window.
            • So bead sealer fixed my tire!!! And I put all 4 on tonight and my brother and I did a little iPhone garage photoshoot as we had no legit camera with us.
              So I'm in love and so hyped for this car season. Other work we found when driving the car was I am rubbing my tubs pretty aggressively on my drivers side so we need to beat it back. And also I need to buy nice hub centric spacers as lining these up sucks...
              • Originally posted by GTOguy View Post
                Poke is out of this world. (literally)
                Looks soo good.
                • Originally posted by SnazzyQ View Post
                  Looks soo good.
                  Lol. Part of me loves it, the other part is ready to get offset topmounts
                    That's it. More camber will solve it but I love the rear fitment!!!
                    • Ordered my top mounts, and extended studs. I am probably just going to hoard parts until my spring break then put them all on at once. Next thing to order will be proper spacers
                      edit: I went ahead and ordered my spacers... So everything should be here before too long
                      • Tad more camber up front and you're sitting on money.
                        • straight up killin
                          Like a glove
                          • Originally posted by Dremetos View Post
                            that is the plan the new top mounts are also noticeably thinner like over an inch.
                            Originally posted by danielsahhhn View Post
                            straight up killin
                            thanks!
                            • Already said it on your IG post but I can't wait to see this at SOWO!
                              • Originally posted by Chuckdee View Post
                                Thanks!!! I am so excited for the show!
