Make it happ'n capp'n.
Project Hardshell
Find me on Instagram - alex_garagezeroeight
1931 Ford Model A project - http://forums.nasioc.com/forums/show....php?t=2362912
When in doubt, cut it out...
Bled the clutch today, also made brackets for the gas tank!
My brother welded supports on my hood vents for structure, and acouple things left to do on that! Also got my new tie rods in, and upper balljoints. Then put the drop spindles on. But now I haz no camber and super poke, so more custom front fenders in the works!
More to come this week!When in doubt, cut it out...
Originally posted by rice4life View Postnot digging the side skirts, too many holes.
I cant wait to see new fendersWhen in doubt, cut it out...
o: to make them flat?
Go for sheet metal or a sort of plastic, fiberglass cracks too easy when a car is that low.
Have you ever considered welding your truck bed and cab to the frame, then weld/attatch the two together to make it similar to a unibody? I have read about people doing it to their 4 runners when installing back seats, or making it an extrarunner.
𝔣𝔬𝔩𝔩𝔬𝔴 𝔪𝔢
@𝔳𝔦𝔳𝔢_𝔪𝔢𝔪𝔬𝔯_𝔩𝔢𝔱𝔦
Have you ever considered welding your truck bed and cab to the frame, then weld/attatch the two together to make it similar to a unibody? I have read about people doing it to their 4 runners when installing back seats, or making it an extrarunner.When in doubt, cut it out...
Originally posted by Isuzupickup View PostNo way! What if you have to take the bed off?!!? ):When in doubt, cut it out...
Had to raise the truck back up so I can drive it once I finish my last couple of mods.Its so high now that I feel that I shouldn't even post any updates until I can get it back to the ground.
Think it was aimed at me o:
With a low truck, I don't really see the use of the bed besides making it look complete, yeah, it has a lot of storage space, but you can't carry much weight anymore without it rubbing, if I remove the back seats of my car I would have as much room. Why would you need to take the bed off anyway, I don't ever need to take the rear end of my car off. I've never owned a truck, so I am probably wrong though.
Get pics of it all raised and stuff
I wonder what these last couple of mods are going to be considering they warrant the truck being raised o:
𝔣𝔬𝔩𝔩𝔬𝔴 𝔪𝔢
@𝔳𝔦𝔳𝔢_𝔪𝔢𝔪𝔬𝔯_𝔩𝔢𝔱𝔦
I wonder what these last couple of mods are going to be considering they warrant the truck being raised o:When in doubt, cut it out...
I don't care if its a truck anymore haha, air shocks wouldn't of helped much thou the mono leaf wasp worn out and floppyWhen in doubt, cut it out...
