Single Turbo 2000 Audi S4 PT5858
  • #31
    Originally posted by KürBFèéleR View Post
    this is incredible. I will be following...sell me your stock wheels?? haha
    Sorry I dont have them. And the 17s I do have I need to use because my stud kit is maxed out and I need bigger spacers for my new wheels to fit so I think Ill be selling my LM reps without tires
    Originally posted by Arteeste View Post
    I like colors going on there
    Thanks. I really like it. Ill take a picture when I get home from school. Those pictures are dark and dont really show the true thing!
    • #32
      Starter, alternator, ac compressor and motor mounts are all bolted up.
      • #33
        What's all left now? Intercooler/setup?
        R.I.P P.WALKER 2013/11/30
        • #34
          Fuel pump
          Injectors/ fuel lines
          Vacuum lines/ catch can
          Down pipe
          Bolt up axles
          Oil cooler
          And intercooler piping which will take some time.
          A bunch of other small things need to get done
          • #35
            this is beautiful
            • #36
              Originally posted by austonwerner4 View Post
              Fuel pump
              Down pipe
              Bolt up axles
              Oil cooler
              Well time to get cracking aye? lol
              • #37
                Its been a long time, Ill make an update today!
                • #38
                  This is looking awesome! Can't wait to see what it's looking like now!
                  • #39
                    • #40
                      So after getting the motor done and in, and ready to start, no start.....
                      Forgot to plug in the rear crank sensors
                      Fast forward.
                      It idled fine, ran kinda okay, but just no power after 4k
                      I only put 10 miles on it. I didn't want to drive it until it was perfect.
                      Now random no start issues occur.
                      Trace it down to a bad Bosch 044 pump
                      Put stock pump in and it ran much better.
                      Took it on a 15 mile drive, and it started to run super bad.
                      Vag it and so many codes I wanted to blow it up.
                      Checked timing with Vag and it was way way off, yet idles fine.
                      Fixed timing, runs worse.
                      Pull the valve covers off and find out cams are 180 out, HOW? Im not sure......
                      So completely fixed the timing.
                      Drove better, same idle as before.
                      3 days before H2O it wouldn't even idle. 400 misfires a minute on cyl5
                      Check injectors, coils, plugs, wires. NOTHING
                      Compression test......
                      NO compression on 5 and between 100-120 on the rest.
                      Replace heads, starts and runs like a dream. Now parked for winter
                      • #41
                        Many more things to come this winter!
                        • #42
                          Exterior:
                          Rs4 front
                          Molded brake ducts
                          Rear with rs6 diffuser or custom
                          Wind shield
                          Hood latches
                          Black roof
                          Interior:
                          Install sport seats
                          Find matching pass race seat
                          Black door cards and rs4 handles in gloss or air leather
                          Black arm rest
                          Euro knee
                          Piano trim
                          Gauge set up
                          Redo led lights
                          Rs4 cluster
                          Compass mirror
                          Air leather flat bottom
                          Brakes:
                          Abs pump relocate
                          18z front
                          Custom rear bbk
                          Cooling plates
                          Suspension:
                          Coil overs rebuilt or new
                          Control arm kit
                          Weld rear sub frame
                          Install sway bar
                          Front end links
                          Engine:
                          Wire tuck
                          Polish ic pipes
                          Carbon fiber air shield
                          Mini power steering
                          Redo piping
                          Fan mount bracket
                          Battery relocate
                          • #43
                            Few pictures. Its been a long time... I stare at something too long and it gets ripped out and changed..
                            • #44
                              [/URL]
                              1968 1600SP Beetle build thread
                              • #45
                                Originally posted by Z33_Taxi View Post
                                Haha
