Nice work.. You get the new motor yet
cb7 accord and other random shit
Hi, i see you put Eibach rear camber kit, do you make other modification in order to have all this negative camber?
I already have an accord, actually it's a CD but those a very similar... and i need negative camber to fitting my rims
thanks for your response and by the way nice project you got there
For the rear no, just the rear upper control arms. I've heard of people having problems with the straight arms hitting the body when going really low though, so I made sure to get the arms with a bend in them. BUT I do need to get rear toe arms to correct the toe now. As the stock bolts won't adjust enough.Originally posted by benrrrra View PostHi, i see you put Eibach rear camber kit, do you make other modification in order to have all this negative camber?
I wish I could trade my heart for an extra liver, just so I can drink more and care less.
thanks. Guess ill update a bit. I did pull the head off the old motor. Visually only 4 valves made any serious contact. But about 8 of them are bent. Cylinder walls still look great so I may keep this motor and re-build it over time just to have a spare laying around.
Also cleaned and painted the stock trans. I may use it, or I might swap to the lude trans. Not sure yet.
